Wheel spinners
Old Apr 29, 2004 | 01:03 AM
gabriel911's Avatar
gabriel911
Cruising
Default Wheel spinners
I bought the spinners for my rims not knowing that they were for the aluminum rims only. I have the ralley rims on my 79 and the back ones will not go on. I am about to have a piece welded to the rim because I really want to put them on. Any ideas???? :beatdeadhorse:
Old Apr 29, 2004 | 10:28 AM
enforcer's Avatar
enforcer
Default Re: Wheel spinners (gabriel911)
I would look carefully at them to see if a little machining could make them fit. I dont have your wheels.
I had the spinners for my 78 aluminum wheels and decided to put them on my Grand National instead. All I had to do was put the thing the spinners screw into on a lathe and take them down a little. I just kept machining them and dry fitting them until they fit good and tight.
You might be able to do something similiar, or do a little welding.
Good luck.
