shift linkage binding
Old Apr 29, 2004 | 02:40 PM
SteelCitiesLT1's Avatar
SteelCitiesLT1
Default shift linkage binding
For the last few days I could not downshift into second or first. Now the car is stuck in third gear. The only position the shifter will go into is the reverse position (feels like fourth gear) and nuetral (third). Any suggestoions on short-term and long-term fix?
Old Apr 29, 2004 | 04:38 PM
adamdinat's Avatar
adamdinat
Default Re: shift linkage binding (SteelCitiesLT1)
Looks like time to crawl under and take it apart.
Old Apr 29, 2004 | 04:42 PM
Fevre's Avatar
Fevre
Might check to see if you shift arm bolts came loose on the trans, after I yanked mine and cleaned it the bolts worked themselves loose and it stuck in gear because the shift arm was free floating on the seat.
[Modified by Fevre, 6:35 PM 4/29/2004]
Old Apr 29, 2004 | 06:16 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
:iagree: It sounds like something is loose or misadjusted. You may want to get new spring clips and add washers under them. That will tighen things up. You can use the Hurst clips that are available at Autozone or a similar parts store.
Old Apr 29, 2004 | 07:58 PM
GDaina's Avatar
GDaina
simple adjustment...get the trans in neutral...just above the xhifter's arms is a hole, find a drill bit that will go inside that hole. This locks the arms into neutral. If your arms are out of adjustment, take them off the tranny and then insert the drill bit. Make the necessary adjustment by the the tranny's shift forks. When everything is in adjustment, you should be able to shift the tranny underneath without any effort....good luck
Old Apr 29, 2004 | 09:57 PM
MGB's Avatar
MGB
St. Jude Donor '14
GDaina, Can the adjustment you described be used on a '78/L82/4speed also. Think my shifter is worn quite a bit and it wants to hang up sometimes also. Thanks
Old Apr 29, 2004 | 10:32 PM
Solid LT1's Avatar
Solid LT1
Default Re: shift linkage binding (MGB)
The shift gates of the Corvette shifter are serviced and the internal shifter gates be purchased and installed. Get a copy of the GM Body service manual and do the troubleshoooting. There can be many causes to the problems you are describing but, most are easilly solved with help from the shop manual.
Old Apr 29, 2004 | 10:53 PM
GDaina's Avatar
GDaina
It won't hurt to try, it will take longer to jack the car up and put stands under then make the adjustment...if it still fails after the adjustment, buy the rebuild kit, that includes new bushings.....all the major vendors carry shifter rebuild kits.
To shift linkage binding
