Edelbrock C66-R
Old May 2, 2004 | 09:09 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default Edelbrock C66-R
Will these even fit on a Big Block under the stock hood? I have a 73 so I believe the hoods were the same?
3.95"/4.65" tall. http://www.edelbrock.com/automotive/man_bbchev.html
[Modified by Guru_4_hire, 9:10 AM 5/2/2004]
Old May 2, 2004 | 12:27 PM
71'AirStrike's Avatar
71'AirStrike
Default Re: Edelbrock C66-R (Guru_4_hire)
:lurk:
Old May 2, 2004 | 09:13 PM
Guru_4_hire
Cruise-In V Veteran
TTT
Old May 2, 2004 | 09:49 PM
LemansBlue68's Avatar
LemansBlue68
I have the C66-O manifold and carbs. They have the same overall dimensions except for the oval ports instead of square ports that you have. This setup does not fit under my stock big block hood ('68). The '73 has a cowl type hood but I think even with that the front carb will interfere with your hood or will likely not leave enough room for the air cleaner. I ended up buying an L88 hood for mine. There's plenty of room with that.
Old May 3, 2004 | 07:13 AM
Guru_4_hire
Cruise-In V Veteran
Default Re: Edelbrock C66-R (LemansBlue68)
Ahh so its a just barely doesnt fit thing. Well that sux.
To Edelbrock C66-R
