Cutting coil springs
Old May 7, 2004 | 08:37 AM
bruced267's Avatar
bruced267
Default Cutting coil springs
Does any one remember the thread on cutting coil springs? I know some one made up a spread sheet of how much spring you cut = how much it will lower the car
Old May 7, 2004 | 09:33 AM
1969BRUCE's Avatar
1969BRUCE
Default Re: Cutting coil springs (bruced267)
JUST REMEMBER THE MORE YOU CUT THE MORE THE SPRING RATE INCREASES.
Old May 7, 2004 | 12:44 PM
Jeffski's Avatar
Jeffski
I cut one coil off my VBP 460 lb springs for the front of my car. That dropped the front approx 1 1/4"
:cheers: :cheers:
Old May 7, 2004 | 05:16 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Do a search for "cutting coils, or lowering front end or coil spring or front coils". :beatdeadhorse:
Old May 7, 2004 | 11:16 PM
bb69's Avatar
bb69
Default Re: Cutting coil springs (Jughead)
I have the spreadsheet. Please keep in mind that this sheet is not exact for several reasons. Number one, the spring rate changes at different positions due to the amount of the spring that comes into contact with the a-arm and frame. Any part of the spring touching other metal (ie the frame, a-arm, or other coils) is inactive. As the spring is compressed, more of it comes into contact with these things, lowering the number of active coils, and increasing the spring rate. Also, careful measurements are required of the coil diameter and the distance between coils. Fionally, knowing how much weight is on the front end is key to knowing how much the ride height will change. I will be glad to provide the sheet, but please understand my sheet is not an exact tool. There are too many variables. It will however tell you how much the rate changes at the free height.
Ken
Old May 7, 2004 | 11:47 PM
comp's Avatar
comp
Default Re: Cutting coil springs (bb69)
close is a good start.... use a cut-off wheel not a torch !!!!!!
Old May 8, 2004 | 12:02 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Cutting coil springs (comp)
I cut about 1 1/4 coil on my 460's and my fender sits about 26" with 26" tires. I also have aluminum heads, intake and water pump and headers instead of the heavy manifolds.
To Cutting coil springs
