Calipers - Std seal or O-ring?
Old May 9, 2004 | 10:30 PM
John Ulrich's Avatar
John Ulrich
Default Calipers - Std seal or O-ring?
I've got a weeping caliper and figure it's time to replace all of them. I see replacements offering O-ringed pistons vs the std piston. Is it worth considering?
Has anyone stumbled upon a deal worth passing on or a good source?
thanks,
JU
Old May 9, 2004 | 10:43 PM
killervette666's Avatar
killervette666
Default Re: Calipers - Std seal or O-ring? (John Ulrich)
Definently get o ringed, theyre more reliable and less likely to leak in the future
Old May 9, 2004 | 10:54 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Re: Calipers - Std seal or O-ring? (killervette666)
:withstupid:
Old May 9, 2004 | 10:58 PM
MN-Brent's Avatar
MN-Brent
Go O-ring. Get the conversion kit after you confirm your calipers are SS sleeved. $130 for all 4 calpiers and your home free. This also gives you the chance to paint 'em up so they look PRETTY. :cheers:
Brent...
Old May 10, 2004 | 12:41 AM
Stoge's Avatar
Stoge
Default Re: Calipers - Std seal or O-ring? (MN-Brent)
My question is, why would someone ever buy standard lip seal calipers? Is there a drawback to having O-ring pistons in your calipers? Everything I have ever heard about them is good... they tolerate run-out better, they are good for cars that don't get driven too much, etc. So why wouldn't someone want o-ring calipers?
Old May 10, 2004 | 09:26 AM
6318's Avatar
6318
Default Re: Calipers - Std seal or O-ring? (Stoge)
Only reason I can think of nonOring is NCRS?
Get the VBP Oring sleeved calipers...just installed mine, love them...
Old May 10, 2004 | 09:46 AM
wcsinx's Avatar
wcsinx
Believe it or not, a lip seal will actually provide a stronger inside to outside seal than an O-ring. But their outside to inside seal is not so good and will tend to leak and/or suck air if the piston is pushed back into the bore (e.g. a warped rotor) hence the springs to keep the pistons pushed out. O-rings on the other hand seal equally well in both directions.
So really as long as your rotors are true, you'll never have a problem related to the lip seals.
To Calipers - Std seal or O-ring?
