Replacing #4 Body Mount 1976
(1) I understand I have to loosen the #3 mount, how hard is it to get to? Any tricks to doing so?
(2) It was suggested that replace the mount attached to the body, which I will be doing.
(3) I am told that I have to raise the body about 3" to replace #4. Where would be a safe place to jack in order to raise the body that far? (I don't have a hoist!)
(4) Will it be possiable to replace the #3 mount at the same time?
Note: The #4 Right side is in not rotted away, so the body appears not to be sagging at thsi point. Due to this will I still need to raise the body 3"?
clip to allow removing the #4 with the others in place.
If you want to be tortured, then there is a small panel in the front of the
rear wheel well that is removed with 4 screws. This gives you just about enough
room to get one click on a ratchet. If the bolt comes loose you are lucky.
These are usually the second rustiest body bolts.
http://nhvette.homeunix.com/images/r...me_drivers.JPG
Another tip that seems popular ...
When doing the #4 - the cage nut will likely be rusted firmly to the bolt.
Cut the head of the bolt from the bottom with a grinder. Then, take out
the nut cage (since you are doing the outer reinforcement, too. When putting
back together, insert the bolt from the top with a washer, and install the nut
at the bottom. I will be starting this job on my body this weekend. I plan on
using 3/16" stainless steel pop rivets. I have some of the stock aluminum
rivets. They will be a pain to get on good in this area.
http://webpages.charter.net/davekimt...t_grinding.jpg
:seeya
[Modified by NHvette, 11:26 AM 5/11/2004]
[Modified by NHvette, 11:28 AM 5/11/2004]
[Modified by NHvette, 7:07 PM 5/11/2004]
As a general rule, spread the lifting force over a wide area to avoid damage to the under body.
I had problems removing the #3 body mount bolt, be sure to use LOTS of PB Blaster etc on the bolts before attempting to remove them.
In addition, often all is not what it seems. You run into unexpected problems. I ended up with a body off - so I could get to that #3 bolt (the cage nut had "spun" and the bolt had to be cut).
In retrospect I should have removed the body first - not that big a deal and with the body off, engine, suspension, etc work is MUCH easier. Lesson Learned :yesnod:
the rear bumper. The bumper cover is attached to the fiberglass of the rear
clip. It is also held on to the frame via the taillight brackets and steel bumper.
If you don't get the bumper cover loose from one of these, lifting the body up
at all will rip the urethane cover ... assuming no-one has replaced with a fiberglass cover.
BTW - You'll only need to lift the corner up enough to get the mount in place.
3" is ample room IMO. A helper lifting up on the fender lip may be enough
Do you have any pictures of what it looks like now ?
:seeya
[Modified by NHvette, 7:15 PM 5/11/2004]
