Rear Wheel Bearings
Old May 11, 2004 | 12:59 PM
Richard Cooper's Avatar
Richard Cooper
Default Rear Wheel Bearings
I'm thinking about replacing my rear wheel bearings on my 81. Can anyone tell me if this is a major job and what has to come off to do this? Thanks in advance. I think mine are original and the car has 140,000 miles on it so I figured I should change them since they do not cost an arm and a leg to buy.
Old May 11, 2004 | 02:56 PM
NHvette's Avatar
NHvette
Default Re: Rear Wheel Bearings (Richard Cooper)
Arm and a leg to get the job done, though.
I'll start with the good news:
You will not have to remove the rear trailing arm pivot bolt.
Now the bad news:
Lots of painful part removing to get them out.
Here is a bare minimum:
1 - release rear spring tension ... leave it bolted up in the center.
2 - get half shafts out
3 - get lower shock mounts out
4 - remove calipers and rotors
5 - remove inner flange from spindle
6 - remove all ebrake shoes/hardware
7 - remove four nuts under outer spindle flange
At this point, you start to wrestle the wheel bearing assembly out of the
trailing arm. A thin screwdriver can be wedged between the bearing carrier
and the trailing arm to get it started. An air chisel would be faster ... but risk damage.
So, at this point you should inspect the trailing arms well. If you think they
need replacing ... talk to Dan at Van Steel and see what he can do.
If TAs look good, then send the bearing assemblies out for refurbishing.
Van Steel or Bairs ... I wouldn't trust a mechanic that isn't a 'vette head.
I did my own, but unless you have a hydraulic press, bearing separator,
bearing packer, and a dial indicator/magnetic base .... it's cheaper to have
them done.
:seeya
[Modified by NHvette, 2:57 PM 5/11/2004]
Old May 11, 2004 | 04:45 PM
GTR1999's Avatar
GTR1999
I was going to write up a procedure for this job last week but found one on http://www.corvettefaq.com already.
Gary
Old May 12, 2004 | 01:27 PM
Richard Cooper
Thank you NHvette and gtr1999 that was great info. Looks like I'm in for so work. :seeya
Old May 12, 2004 | 02:45 PM
Sapas's Avatar
Sapas
Cruising
This is a big job, so if you want to tackle it be prepared to take awhile. Did this on my 79 and it is a real pain. It helps to have all the right tools that you need. Trying to guess wheel bearing shims for play is alot of taking apart two or three times.
Good Luck,
Have Patients,
Lon
Old May 19, 2004 | 10:22 AM
iPlanet's Avatar
iPlanet
Default Re: Rear Wheel Bearings (Sapas)
Before you start tearing things out try this 1st. power wash the rear end make sure you get all the crud and rust out. Next let it dry out then spray all moving parts with a good oil spray let that soak in for a few hours and then repeat. Now you can do a proper diagnoses. If you cannot locate the area that is producing the noise then I suggest to take it to a good rear end shop and let them diagnose the problem and at that point you can make a decision. I will say this do not touch the rear end unless you know what you are doing in most cases the rear end is more complex to set-up then rebuilding an engine. Some times it's wise and cheaper to let a pro do it.
[Modified by iPlanet, 6:24 PM 5/19/2004]
To Rear Wheel Bearings
