Temperature Sending Unit
Old May 17, 2004 | 10:52 AM
Raydon 3000's Avatar
Raydon 3000
Default Temperature Sending Unit
I rebuilt my 1970 350. Before the rebuild the temperature gage read correctly. I replaced the temperature sending unit with one from Auto Zone during the rebuild. After that the gage did not go above 160 degrees. I checked the wiring- good. I replaced the sending unit again, with one from Auto Zone. I got the same readings. Neither of the new sending units looked exactly like the one I replaced. I discarded the original. Does the gage require a special sending unit? How can I check out the gage? Help!!!
Old May 17, 2004 | 11:11 AM
jbroughton's Avatar
jbroughton
Default Re: Temperature Sending Unit (Raydon 3000)
Everything I read about these sending units said that none of the aftermarket units are calibrated correctly for our cars. Lectric Limited sells one that is supposed to be correct. I bought one a few weeks ago, but haven't installed it yet, so I can't vouch for its accuracy.
Hope that helps!
Jeff
Old May 17, 2004 | 11:13 AM
Larry B.'s Avatar
Larry B.
Default Re: Temperature Sending Unit (jbroughton)
You need one from 'lectric limited. They are correct http://www.lectriclimited.com/mainpage.htm
[Modified by Larry B., 11:18 AM 5/17/2004]
To Temperature Sending Unit
