700R4 Speedo Gears
Old May 18, 2004 | 02:59 AM
78Vette-SA's Avatar
78Vette-SA
Default 700R4 Speedo Gears
I've got a 700R4 goint back to a 3.55 rear. I'm running 255/60-15 tires. Could someone suggest which speedo gears to use? Currently I'm reading about 100mph when only doing about 60.
I pulled the speedo gear out and it looks like a 38T. Do I need to go larger or smaller (I have an 18T lying around) and do I need to change just the one gear?
Old May 18, 2004 | 03:28 AM
mrvette's Avatar
mrvette
Default Re: 700R4 Speedo Gears (78Vette-SA)
From what you say it seems you will need to change the drive gear on the output shaft also, I don't htink you can get 55-60 tooth driven gears....which is about the range you would need with that drive gear.....
sounds like the rear ratio that tranny came with originally must have been like a 2.73 assuming fairly similar tire diameter....
GENE
Old May 18, 2004 | 08:19 AM
SpyderD's Avatar
SpyderD
Should answer your questions:
http://www.transmissioncenter.net/sp...n_______va.htm
Old May 18, 2004 | 10:50 AM
GasketDude's Avatar
GasketDude
You need to check the color and teeth number of the drive gear in the transmission. I believe you may have a 15 tooth gear which is grey in color. If so, based on your 255/60/15 (27.1" tall tire), 3.55 gear, you'll need a 40 tooth black driven gear. GM part# 1362048 which is still a good number and cost about $5.50 list.
Good luck.
Old May 18, 2004 | 09:46 PM
78Vette-SA's Avatar
78Vette-SA
Default Re: 700R4 Speedo Gears (GasketDude)
Thanks for the help and suggestions guys.
Question though. If I currently have a 38T (Blue) driven gear and am hitting 100mph at about 60, is 2 teeth going to be enough of a change (to a 40)?
Old May 18, 2004 | 10:15 PM
Ronny's Avatar
Ronny
I have same set up on my car and BTO sent me a 17T shaft gear and a 45T speedo gear to make my speedo read correctly. They said both gears must be changed to make a large adjustment to calibrate speedo. Have not installed because I installed digital instructments and being electronic they have a built in calibrating function.
Old May 18, 2004 | 10:48 PM
joe73vette's Avatar
joe73vette
Default Re: 700R4 Speedo Gears (Ronny)
I recall that a one tooth change in the driven gear is good for about a 3 MPH difference. Joe
Old May 19, 2004 | 08:56 AM
GasketDude's Avatar
GasketDude
You may have a different color drive gear in the transmission. Find this out, and repost this color/tooth count.
A 15t drive/ 40t driven calculates the same as a 17t drive/ 45t driven. Most people try to change only the driven gear because it's the easiest to get to. So bottom line is find out the drive tooth count and go from there.
Old May 19, 2004 | 09:20 AM
mrvette's Avatar
mrvette
78, good observation and the answer is obviously NO.....you need most likely change both gears....
GENE
To 700R4 Speedo Gears
