255/70R15?
Old May 18, 2004 | 03:54 PM
Crash80's Avatar
Crash80
Default 255/70R15?
Is there any reason that a tire sized 255/70R15 wouldn't work on my 80? I know the two sizes are 225/70R15 (currently on my car) and the optional 255/60R15 but would this other size work possibly? I think I found a lead on the Goodyear Eagle #1 (not NASCAR edition) in this size and am hoping it might just work. What do you all think?
Old May 18, 2004 | 04:06 PM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Default Re: 255/70R15? (CVT4ME)
That tire is pretty big compared to stock. About 1.5" larger in diameter. My guess is that you'll end up with clearance problems. Either rubbing on the frame, or the wheelwell, or some other chassis component.
Old May 18, 2004 | 04:08 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
Default Re: 255/70R15? (ddecart)
:iagree:
Old May 18, 2004 | 04:12 PM
Solid LT1's Avatar
Solid LT1
TOO BIG! let the SUVs use those. Pirrelli makes a "VR" speed rated scorpion in a 255/60/15 size. You do know that the 78-82 cars with this size tire did have some fender mods done to them, don't you. Chevy cut the inner lip at the leading edge and sometimes at the back edge too, for clearance with the 255/60/15 Goodyears. Be sure and check your fenders to make sure any wide tires clear, they rip-off very nicley on tire contact during hard cornering.
Old May 18, 2004 | 04:42 PM
Crash80's Avatar
Crash80
Well, it figures. I have been looking high and low for these tires. I was sort of hoping that since the size was sort of of a hybrid between the two factory offered tire sizes that it might work. I figured it would just be a wider version of the standard size that might work. The tread width is 10.2 with a diameter of 29" for a rim width 6.5-9.0 inches. Thanks guys!
Old May 18, 2004 | 05:32 PM
Crash80's Avatar
Crash80
...OK, not to keep beating this dead horse but what about a 275/60R15. Anyone tried that size with any success? The dimensions would be a tread width of 10.9 and a diameter of 27.9 if that helps.
[Modified by CVT4ME, 4:33 PM 5/18/2004]
Old May 18, 2004 | 05:48 PM
page62's Avatar
page62
Too wide :beatdeadhorse: Just get the El Cheapos and you'll be happy!
Old May 18, 2004 | 05:51 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
maybe on a tractor.
why not go with 255/60/15
Old May 18, 2004 | 06:20 PM
noir76's Avatar
noir76
Default Re: 255/70R15? (turtlevette)
The techs at Tire Rack are really excellent with fitment questions even if you're not buying tires from them, although they do have great prices. :thumbs:
Old May 18, 2004 | 08:24 PM
Paul L's Avatar
Paul L
You will run into serious speedometer correction problems if that matters to you.
Old May 18, 2004 | 09:24 PM
JohnS_77's Avatar
JohnS_77
Default Re: 255/70R15? (paul67)
When I buy tires for my 77, I'm getting 245/60R15.
:steering:
Old May 19, 2004 | 11:45 AM
Crash80's Avatar
Crash80
The 255/60R15 is the optimal size that I would like to go for but with the line on the tire I found I can't get that size. Currently there are 225/70R15 Goodyear Eagle GT+4 with decent tread left on them but I think they are close to 10-12 years old. Now that I think about it, I have read you can get a 275 in the back with moving the e-brake cable bracketing. Sounds like too much of a hassle to me.
Yeah, I know Page, I have put more work into tire hunting than a sane man should. To me, the look of the tire is important on a Vette. I am not worried about speed ratings and all that jazz...not on this Vette. There would be pistons and valves all over the roadways way before I could reach 112MPH. :jester
I am basically looking for old stock tires in a Goodyear Eagle 1 street radial or a Firestone SS20...a slim chance in hell, I know. If all else fails, there is always the Goodyear Eagle Nascar, Firestone Indy 500, or BF Goodrich Radial T/A in sizes that will fit.
If I can't find what I am looking for, I am leaning toward the Eagle Nascar and blacking out the Nascar letters, or getting the Firestones and making the Firestone lettering white with tire markers.
I am just that weird!
Old May 19, 2004 | 12:33 PM
cw823's Avatar
cw823
Default Re: 255/70R15? (page62)
275/60/15's on the rear of my 79 that don't rub at all.
Old May 19, 2004 | 12:50 PM
lowvette's Avatar
lowvette
Default Re: 255/70R15? (JohnS_77)
:steering:
This is what I have on my '77. It's getting harder to find tires in sizes for C3s. I used to buy Goodyear, BF Goodrich or Michelin, but now settle for Dunlap GT Qualifiers.
The 245's fit well, but are a little close to the rear spring. Much wider and I'd look at more extensive mods.
Old May 19, 2004 | 02:28 PM
LiveandLetDrive's Avatar
LiveandLetDrive
Default Re: 255/70R15? (cw823)
:withstupid:
I have Pirelli Scorpion Zeros in this size (VR rated) Love the width. Might have to relocate or remove the Ebrake bracket to make them not rub though. The 28" diameter looks great. 255 60R15 would be my second choice, and the safest.
-Chris
Old May 20, 2004 | 12:36 AM
WAYWRONG's Avatar
WAYWRONG
I rub bfg comp t/a 235/60 hr15 on front and 255 on rear no problems
Old May 20, 2004 | 12:44 AM
Stoge's Avatar
Stoge
Tires that size will probably rub the body when turning and hitting bumps at the same time. I have BFGoodrich Radial T/A 255/60/15's on mine and the clearence is a bit tight with the wheels turned either direction.
Old May 20, 2004 | 10:29 AM
Crash80's Avatar
Crash80
Default Re: 255/70R15? (Stoge)
I think I am going for the Nascar Goodyear Eagle in the 255/60R15 size. I will black out the Nascar letters giving it the look below. I know it makes the rest of the RWlettering asymetrical but I kind of like the look. I may even like the look of the Nascar letters once I get them mounted...who knows!?
[Modified by CVT4ME, 9:32 AM 5/20/2004]
To 255/70R15?
