rpm airgap
Old May 19, 2004 | 09:09 AM
wadey's Avatar
wadey
Default rpm airgap
Will an rpm airgap intake fit under a '76 vette's hood? I will be using a drop base air cleaner. Also if anyone is currently using this intake could you please
give your impressions.
thanx wade
Old May 19, 2004 | 09:14 AM
Ganey's Avatar
Ganey
Default Re: rpm airgap (wadey)
The 73-79 med. rise hood allows the RPM & others w/ aftermarket dropbase & Holley.
You need to give your setup incl. carb & what you want if you want to know if you should use it.
Old May 19, 2004 | 10:37 AM
AV8RSVT's Avatar
AV8RSVT
Default Re: rpm airgap (Ganey)
I have decided to use the Edelbrock "torker II" on my 72 small block. I have A mild 350 4-speed. Also I will run A drop base. :cool:
Old May 19, 2004 | 12:15 PM
thebruce's Avatar
thebruce
A 1 inch drop base fits under the hood of my '74 with a 2 inch filter.
Old May 19, 2004 | 10:38 PM
79-L-82's Avatar
79-L-82
Default Re: rpm airgap (thebruce)
This seems awfully familiar.
:blueangel:
Check my post called intakes and hood clearance.
It's fairly new. . . :thumbs:
To rpm airgap
