starting problem ? Ignition switch?
Old May 20, 2004 | 02:32 PM
vette75406's Avatar
vette75406
Default starting problem ? Ignition switch?
I have a 75 with a minor problem , the starter will not even try to start the car when using the key to crank (nothing), the neutral safety switch is bypassed , I have a underhood MAD remote starter button that will start the car , this problem would come and go but now appears to be permanent, also no interior lights with the door open , when I did get interior lights the car would start with the key , factory security and interloc relay have been long ago disabled, before I owned it. I'm thinking Ign. switch on top of column any other ideas?
Old May 20, 2004 | 08:09 PM
lyonsh's Avatar
lyonsh
Default Re: starting problem ? Ignition switch? (vette75406)
Ok, this is probably a stupid question, but: Have you checked the battery and connections? Simple things first.
Old May 20, 2004 | 08:22 PM
Wamplet's Avatar
Wamplet
Default Re: starting problem ? Ignition switch? (lyonsh)
^ yeah, I second checking the battery.
My Fiero's battery was corroded and the car wouldn't turn, nor would any lights come on.
Had to get a new terminal bolt and some other stuff to clean the crud off about 3 weeks ago. :D
Old May 20, 2004 | 10:40 PM
vette75406's Avatar
vette75406
yeah , got a hot battery , ive been working on other things on the car , and have not been trying to fix this exact problem , im gonna try another ign switch just in case , ive got a new spare, and see what happens , thanks
To starting problem ? Ignition switch?
