Rear Rotor Removal Question
Old May 20, 2004 | 02:56 PM
82Powerhouse's Avatar
82Powerhouse
Default Rear Rotor Removal Question
1982 Corvette
I am trying to remove the rear rotors so that I can replace the parking brakes, but I am having trouble. The Haynes book that I have says in one part to drill the tops of the rivets off to remove the rotors. I did this, but it did not work. In another part, it said to DRILL OUT the rivets, not just the tops of them. I am going to have to go and get another drill bit if I am going to have to completely drill them out. Any help on this matter would be helpful. If it is just the tops, then any suggestions as to why I am having a hard time getting the rotors off.
TIA,
CDM
Old May 20, 2004 | 03:17 PM
markdtn's Avatar
markdtn
Default Re: Rear Rotor Removal Question (82Powerhouse)
Probably have to drill them completely out. Those rivits are a major PITA. But, you don't have to put them back.
Old May 20, 2004 | 03:54 PM
72GACRZR's Avatar
72GACRZR
You don't have the parking brake on, do you?
Here's a past thread that might help.
http://forums.corvetteforum.com/zerothread?id=376002
To see others, do a search on "rotor removal" in the archives :seeya
[Modified by 72GACRZR, 3:59 PM 5/20/2004]
To Rear Rotor Removal Question
