Coolant on the ground
Old May 21, 2004 | 06:58 PM
sjr1971's Avatar
sjr1971
Default Coolant on the ground
Been watching my '71 454 sporatically vent coolant. Motor has 2000mi since rebuild. New H20 pump,heater core, radiator. Shake city; headgasket! No auga in the oil, coolant. No H2O in the exhaust. WTF?? Car sat for 12yrs. Found Aluminium rust on the rad. filler cap seal. Cleaned: still vents. Don't want to hear this. Read new post on corvette.faq. I did twist my upper rad hose to clear the generator. I'm now rooting for High school Psycics
Old May 21, 2004 | 11:44 PM
Larry B.'s Avatar
Larry B.
Default Re: Coolant on the ground (sjr1971)
An air leak or bad radiator cap will cause this too. Also check to see if the lower hose is sucking shut when you rev the engine.
Old May 22, 2004 | 01:14 AM
lostpatrolman's Avatar
lostpatrolman
Default Re: Coolant on the ground (Larry B.)
You could just be simply filling the radiator up too high. If you fill it to the top, some fluid could leak out of the overflow after the car is shut off. Once the car is shut off, the fluid gets hotter then it was while the engine is running. Sometimes it will boil. If it boils, some fluid will be forced out of the radiator. If you are worried about the fluid leaking out, get a reservior tank, or a catch can.
Old May 22, 2004 | 03:26 AM
stingraymaniac's Avatar
stingraymaniac
Default Re: Coolant on the ground (lostpatrolman)
can you see on the floor where its coming from?
i mean is it in front,back,ore the sides off the engine?
Old May 22, 2004 | 05:18 AM
Larry B.'s Avatar
Larry B.
Default Re: Coolant on the ground (stingraymaniac)
IT kinda goes without saying, If you fill the system COMPLETELY full, it will vent water until ig gets to the normal amount when warm.. Warm things (including water]expand.
Old May 22, 2004 | 03:42 PM
sjr1971's Avatar
sjr1971
I was really referring to the corvette.faq piece. I found Al oxide on the rad cap gasket and that was definitly a leak. The article is about air getting trapped at the high point of the syst causing vapor locks and increasing syst press to above your cap's max. I wouldn't have ever thought of that one. Twisted the upper hose to below the cap level and voila no coolant on the ground. All you guys are an ocean of knowledge
Old May 22, 2004 | 04:29 PM
Larry B.'s Avatar
Larry B.
Thanks for the compliment.. I discovered that about 20 years ago with my BB 70. I blew a hose, replaced it with a generic replacement and that's when the problem started. This is a common thing... believe it or not. It is just not obvious. There are lots of aftermarket hoses out there to make matters worse. I'm glad it was that simple.
Old May 28, 2004 | 11:58 PM
sjr1971's Avatar
sjr1971
Polished the expansion tank's seal till it shined.Put the old cap[visiably thicker spring] back on after pulling the rubber gasket off the cap and reversing the gasket so the unused side now formed the seal. 4 runs in 80+ temps. No puddles. SO far.
To Coolant on the ground
