Question regarding installing new engine.
Old May 24, 2004 | 11:00 AM
KJL's Avatar
KJL
Default Question regarding installing new engine.
I will be dropping in my new engine next week and am not sure if I should attach the motor mounts to the engine or to the frame first. My trany is jacked up as high as it will go. My guess is to attach mounts to engine, couple the engine and trany, then drop the trany jack and lower coupled unit into place on the motor mount arms and then just slide the bolt through.
Any helpful hints?
Old May 24, 2004 | 11:23 AM
Fevre's Avatar
Fevre
Default Re: Question regarding installing new engine. (KJL)
Yes attach them to the eng, much easier to get the one bolt through the mounts and frame then try to get one of those small ones to line up on the and plus the eng can just drop into place using the mounts as guides.
Old May 24, 2004 | 12:28 PM
markdtn's Avatar
markdtn
Default Re: Question regarding installing new engine. (Fevre)
:iagree: and if you have help it is easier IMHO to install the tranny out of the car.
To Question regarding installing new engine.
