Got some Free Double Hump Heads
[Modified by markdtn, 2:11 PM 5/24/2004]
Companies like Zoop's and March make brackets to mount everything without using head bolt holes.
Look at March for their mounting kits. It may seem expensive, but it will be a hell of a lot easier than maybe getting the holes correct in the head. And even if they get the holes right, you've trashed some of the value on those heads. Restorer's have wet dreams about getting some of those without the holes in them.
Better yet, e-bay them and mount up some aluminum vortec heads or aluminum twist flows.
It'd be cheaper to get a new set of state of the art heads, versus having those heads comlpetely reworked, but some machine shops would "forget" to mention that fact.
I have an old non-matching set of stock castings that I've held onto for a couple of years. I'm gonna use them to practice porting on, eventually. They aren't worth any performance, and too much machining needs to be done to them.
No matter how you look at it, it's going to cost some money. You'll have to pay to ship them, send them to a machine shop to get magnafluxed, and to get an estimate on what it will cost to make them useable (valves/seats reground and valve guide, holes drilled).
There are a lot of a-holes out there that will buy them on E-Bay. All they know is that the double humps performed great, but that was 30 years ago and today's heads are much better. One man's junk is another man's treasure.
The heads should work fine on a street engine and be an improvement over what you currently have. The other good thing about them versus the vortec's is that you can use your existing intake. If you’re planning to buy a new intake then that gets thrown out the equation. I for one do not believe in spending time and money in changing one item when re-doing an engine. I feel it is best to save up and do what needs to be done to get the performance where it should be. As long as the short block is in good shape, change the cam, timing chain/gears, intake, push rods, rockers, etc. You can then feel good that you'll get quite a few years of trouble free engine life.
Mike
'461 and '462 numbers have no accessory holes. They are not strong enough to
drill holes as others have said.
The World Torquers or Protopline torkers are the aftermarket equivalent and work
with the older intake manifolds and rocker covers, unlike the cheap vortecs!
It has been shown around here that getting heads like these two aftermarkets are
cheaper overall than switching to a vortec head given the additional costs of newer
parts.
Good luck.
