Hp predictions?
Old May 24, 2004 | 08:48 PM
killervette666's Avatar
killervette666
Default Hp predictions?
I just recently got a new cam for my 79 L-48 with a performer rpm intake, true dual chambered exhaust, 650 cfm speed demon carb, as well as a recurve kit, and vacuum advance kit, the specs of the cam are as follows, Advertised duration: 282 intake/282 exhaust, Duration at .050 in. cam lift: 224 intake/224 exhaust. How much hp could i get out of all of these mods, i have already removed ALL smog equipment. Any predictions on qtr. mile times? :cool: :cheers:
Old May 24, 2004 | 09:26 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Hp predictions? (killervette666)
With the limited information you gave, just plugging guestimates into DD2000, comes up with 300hp/345lbft torque.
Just a guess on your 1/4 mile time, since I have no idea about gears and etc. but I know of a stock 1970 convertible with a 350/300hp,TH400 automatic, 3.08 rearend has run pretty close to 15.0 flat in a quarter.
Old May 24, 2004 | 09:33 PM
killervette666
Default Re: Hp predictions? (Smokehouse69)
Sorry that i dont have more info, i've never really measured any of the specs on th engine, such as compression and other details. 15 sec? is that mainly because of the rear gears? Also i have taken off about 300 lbs of weight.
To Hp predictions?
