1981 Carburetor Question
Old May 25, 2004 | 02:10 PM
Biker's Avatar
Biker
Default 1981 Carburetor Question
I noticed the solenoid switch on my '81 never seems to operate. I'm referring to the solenoid that has plunger. The plunger is positioned behind the carb's throttle linkage. What is the purpose of this device? Can I test it by applying 12 volts directly to its wiring connections? If it's inoperable, should I worry? The car runs warms up, idles and runs just fine. As stated, my only concern is I've never seen the solenoid/plunger operate, not even when the engine is cold. Thanks.
Old May 25, 2004 | 02:24 PM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
Default Re: 1981 Carburetor Question (Biker)
from what you describe, it sounds like your talking about the 'fast idle' solenoid. it should kick the throttle up when you first start the car when cold. does the car go into fast idle first thing? it also is supposed to idle the engine up with the A/C on. you should notice the solenoid extend and apply more throttle when the A/C is turned on. is that the solenoid your talking about?
if so, you don't need it. i haven't had mine on my car in years. but i do have to manually (or should i say "footually") keep the throttle up when starting cold.
"footually". geez, that's bad! :rolleyes:
Old May 25, 2004 | 02:33 PM
Biker's Avatar
Biker
Default Re: 1981 Carburetor Question (clutchdust)
My engine goes into a fast idle when its cold. So from the above description, it sounds like the solenoid is working properly.
Old May 25, 2004 | 02:36 PM
Garys '68's Avatar
Garys '68
Yep, Qjets have a solenoid that bumps up the throttle stop when the AC is on. Prevents the engine from dropping too many rpms. Start the engine, turn the AC on and see if it pushes out. If it doesn't and there's voltage to the solenoid, you can replace it.
But it is not absolutely necessary. You can turn up the idle or footually operate it.
Gary
[Modified by Garys '68, 7:37 PM 5/25/2004]
Old May 25, 2004 | 03:19 PM
page62's Avatar
page62
That solenoid only works when the A/C is on. The choke mechanism causes the fast idle when the engine is cold. Test it by having someone switch the A/C on and off while you watch the solenoid.
Old May 26, 2004 | 02:11 AM
stickboy's Avatar
stickboy
Default Re: 1981 Carburetor Question (page62)
:iagree: It's adjusted by crewing the plunger in/out. You could also test by applying 12 volts to the lead
Old May 26, 2004 | 02:12 AM
RC81's Avatar
RC81
As they said, turn on your ac while watching it. It should pop out a bit to up the idle while the ac is on.
Old May 26, 2004 | 06:57 AM
UKPaul's Avatar
UKPaul
Default Re: 1981 Carburetor Question (RC81)
As Page said, fast idle is controlled by the carb from cold.
It's hard to spot as it only moves very slightly. I took mine off & everything worked fine afterwards (then I liked the cleaner look so much that I went overboard & pulled the entire aircon system off the car :) ). It's just extra clutter under the hood so pull it off! If you disconnect its wire & the engine doesn't stall at idle when you turn the aircon on then you don't really need it, it's just extra weight slowing you down. Go faster, go footually.
:cheers:
To 1981 Carburetor Question
