TH400 Shift kit
Old May 25, 2004 | 03:32 PM
Gage's Avatar
Gage
Default TH400 Shift kit
Anyone out there installed one of those B&M $30 shift kits in their car? Is it complicated for a the do-it-yourselfer. On the board I see a range of guys who are as advanced as machining their own parts to guys who think changing oil is a challenge(C4,C5 guys)...I fall somewhere in the middle. My GTO had a TH400 with one already installed in it and I liked how it shifted.
Old May 25, 2004 | 03:38 PM
mrvette's Avatar
mrvette
Default Re: TH400 Shift kit (Gage)
Trans Go is the far better kit, even if more expensive....get the tow package or race version....
GENE
Old May 25, 2004 | 03:41 PM
Stewart's74's Avatar
Stewart's74
Default Re: TH400 Shift kit (mrvette)
:iagree: The Trans Go kit is the best on the market. I bought mine here: http://www.bulkpart.com.
Old May 25, 2004 | 03:49 PM
Gage's Avatar
Gage
Default Re: TH400 Shift kit (Stewart's74)
Thanks for the advice...Did you guys install it yourself, ie the only thing I have ever done to an automatic is change fluid and filter...Do the instructions that come with it do a nice job of walking you through it.
Old May 25, 2004 | 05:06 PM
JJ Deuce's Avatar
JJ Deuce
I put the TransGo kit in myself. There's not a whole lot to it. You have to drop the valve body (be careful not to lose the check *****). The new accumulator spring was a little tough, too. If you've done the filter before, though, it shouldn't be too much for you.
Old May 25, 2004 | 05:38 PM
GTR1999's Avatar
GTR1999
Don't know about the TransGo kit,I'm sure it's a quality kit. I have the B&M TransKit to do a complete rebuild. Most of the mods are common among the kits I believe. I can't tell you how it works because I'm only 1/2 way through the rebuild. Trans is apart,cleaned up,a and ready for rebuilding just haven't had the time yet. :nopity
Gary
Old May 25, 2004 | 05:49 PM
Gage's Avatar
Gage
Default Re: TH400 Shift kit (Jeff 6T9)
Does the Transgo kit come with instructions?
Old May 25, 2004 | 06:14 PM
NHvette's Avatar
NHvette
Default Re: TH400 Shift kit (gtr1999)
Gary
I set mine up street/strip with the B+M Transkit rebuild.
I would never switch it back.
:seeya
To TH400 Shift kit
