Backfire thru carb & lil' tapping...
Old May 26, 2004 | 11:06 AM
Jack71's Avatar
Jack71
Default Backfire thru carb & lil' tapping...
For the record.. I'm paranoid. All the time.
When I start the car and its warming up, there's an occasional backfire thru the carb. It only happens when the car is warming up. I also hear a slight tap thats there all the time. Sounds like a valve, that familiar "tick" sound.
Remember, I'm paranoid. Could they be related? Here are some facts...
- Rebuilt engine has about 250 miles on it.
- Hyd roller cam in it
- Engine currently as a 670 Holley Street Avenger which is a little small, but that shouldn't have a negatve impact.
Any help appreciated...
Did I mention I'm paranoid? I'm getting ready to drive the car from NJ to Massachusetts in a week or so. I really want to get there...
--Jack
Old May 26, 2004 | 11:11 AM
Fevre's Avatar
Fevre
Default Re: Backfire thru carb & lil' tapping... (Jack71)
Might have a loose rocker arm or exhaust leak.
Old May 26, 2004 | 11:20 AM
Gordonm's Avatar
Gordonm
Default Re: Backfire thru carb & lil' tapping... (Fevre)
If the pistons are forged you could have a little piston slap due to the clearance. Once it warms up it should go away. Mine is a bear to keep running when cold and makes a lot of racket with the solid lifters and forged pistons. If it goes away when warm you should be OK
Old May 26, 2004 | 11:24 AM
Jack71's Avatar
Jack71
Default Re: Backfire thru carb & lil' tapping... (Gordonm)
Exhaust is tight, no leaks. The engine is all forged, but the cam doesn't have a tremendous amount of lift... like .509 plus 1.6 rockers.
Old May 26, 2004 | 11:52 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I had that anoying tick-tick sound on 3 GM SB's. Once was a blown header gasket one was a stripped exhaust manifold bolt and the third was simply a loose exhaust manifold.
Old May 26, 2004 | 12:38 PM
70454's Avatar
70454
I had a similar problem and found that I had adjusted the valves too tight. Caused the engine to rock back and forth and it was spitting.
Loosened the valves to zero lash and re-tightened.
Old May 26, 2004 | 01:01 PM
gerry72's Avatar
gerry72
I had a problem like that in another engine. Turned out the valve guide was too tight. Eventually, the valve seized in the guide and got acquainted with Mr. Piston. Normally this is a hot engine issue since the valve expands more than the head and closes up the clearance. You wouldn't tend to notice it when cold. When it occurs and how long the tapping lasts would be good to know. It could be something as inert as a lifter bleeding down needing a couple of seconds to pump up.
That you have a backfire through the carb indicates that your mixture may be lean(carb mixture or vacuum leak), that your timing is off, or that you have a valvetrain issue. Me, I'd look for a vacuum leak first but you'd have to provide more detail under what circumstances the backfire occurs. Otherwise we're all just guessing in very broad areas.
Old May 26, 2004 | 03:03 PM
Boofers's Avatar
Boofers
Default Re: Backfire thru carb & lil' tapping... (gerry72)
Has my vote
Old May 26, 2004 | 05:07 PM
Wrencher's Avatar
Wrencher
With the low miles, I'd suspect slightly retarded timing (probably timing chain stretch - they do it within a few miles) on the cold start pop, and slightly loose rocker. Re-adjust it all and then see how it works.
Hans
To Backfire thru carb & lil' tapping...
