Frame off Resto in progress
Old May 26, 2004 | 05:33 PM
brew'69's Avatar
brew'69
Default Frame off Resto in progress
Hi everyone,
Im doing a frame off on a '69 corvette Coupe 350/300
It has a turbo400 trans original color is Daytona yellow w/ black interior and is a original
sidepipe car w/ air.
The engine I have just finished, bored .30 over new pistons, rings, bearings, It has a Crane
energizer cam with 202 double hump heads & 4 bolt main, 302DZ alunium intake & a
750 dual line Holley.
I recently bought dual ring rockcrusher w/ bellhousing and going to make a 4spd out of
the car
Last Saturday I pulled the body off and I am in the process of tearing it down to a bear
frame.
I was wondering what was the best catalogs to order out of the get the parts needed to
finish the project. The most affordable (he, I think that was a joke) I found was Voluteer
Vette out of Knoxville.
on the frame I have power steering but it is in need of being re-built. would I be better off
to get the steeroids system while I have it apart? also is there a kit to make for a fluid
clutch conversion? Is the VBP composite monospring hold up well over time or are they
any issues with it? I will try to get some pics of the car tomorrow to post
thanks for the help
Bryan Brewster
69 coupe
Old May 26, 2004 | 07:30 PM
NHvette's Avatar
NHvette
Default Re: Frame off Resto in progress (brew'69)
Welcome, congrats, and good luck.
All the mods you mentioned are a matter of $$ and personal preferrence.
Lots of variability with the 'glass springs. If I changed from steel, it would be with the VBP dual mount rear ... adjustable rate and height.
I've never seen a hydraulic clutch conversion, but it can obviously be done -
matter of time and $$.
I hope you don't want to drive her soon. The resto just snowballs.
As for cheap ... Volunteer is OK - as most. Nuthin's cheap, but compare the
parts with say parts for a new Volvo .... the vette's not that bad.
:seeya
Old May 27, 2004 | 01:38 PM
brew'69's Avatar
brew'69
Default Re: Frame off Resto in progress (NHvette)
I have noticed the Snowballing effect every time I go in the garage :banghead: or at least my wallet does
Old May 27, 2004 | 04:05 PM
PureSilver's Avatar
PureSilver
Time is the big factor. As for wish-books- VBP for suspension & brakes, VanSteel (you want all new bearings if you're going this far-plus he can do the same stuff as VBP), Zip's, Rik's, Summit Racing or equivalent. Shop between the 'Vette specialty catalogs as the prices will vary some.
I am doing the same frame-off renovation thing on my '78-I went with the Steeroids kit and the hydraulic power brake assist (eliminates vacuum) that you'll see on the Forum. Look for group purchases of lots of this stuff- they come up from time to time, and most vendors will give some kind of discount if you are a Forum member anyway.
You may want to fully weld all the frame seams to stiffen the frame, and repair and reinforce certain areas (like the front suspension mount points) that commonly show cracks or rusting.
I wish I had the bucks to get a five- or six-speed gearbox (for keeping in the power band when running hard, & maximizing fuel economy when not), but am sufficing with the standard Muncie.
Good luck- keep us posted on your progress.
Old May 27, 2004 | 04:10 PM
wacked's Avatar
wacked
From: If the world didnt suck, we would all fall off. Troy,Ohio.
Cruise-In VI Veteran
St. Jude Donor '04-'05-'06-'07-'08
Default Re: Frame off Resto in progress (PureSilver)
Hi :seeya
Old May 27, 2004 | 06:57 PM
brew'69's Avatar
brew'69
(first time trying to put pictures on the net this may take a little trial and error)
Should be a picture of my frame
Brew
I hate technology sometimes...
[Modified by brew'69, 12:07 AM 5/28/2004]
Old May 28, 2004 | 11:16 AM
l2vette's Avatar
l2vette
Check out Doc Rebuild if you want to keep things as stock as possible. They have a real good catalog and the prices are the best I've found. As far as the composite leaf spring goes, I had the 340 lb. TRW and it made my 72 Vette look like a 4 x 4 even with the 8" bolts. The stock steel spring worked best for me, I was able to set the car up at factory F41 specs. Good Luck.
:cheers:
Old May 28, 2004 | 11:35 AM
ACECO's Avatar
ACECO
St. Jude Donor '04 & '05
Welcome to the insanity! :crazy:
Check out Wilcox. They have great service and their prices are very good for what they carry. I've had good luck with them so far.
http://www.yankeelady.com/willcox/
Good Luck w/the project. :yesnod:
:seeya
[Modified by ACECO, 11:59 AM 5/28/2004]
Old May 28, 2004 | 01:12 PM
brew'69's Avatar
brew'69
Default Re: Frame off Resto in progress (ACECO)
Thanks for the tips! I will probly use Willcox on some of the parts Im going to buy.
Brew
Old May 29, 2004 | 02:37 PM
brew'69's Avatar
brew'69
I got some pics of my car (or parts I should say) I was going to post but I cant seam to get them posted can anyone help?
Also, on a 5 spd conversion does it use a 4spd bell housing and a fluid clutch? if so would you be able to use the fulid cluth on a 4spd? I found a few conversion for fuild cluthes but they are all for ford toploaders.
Brew
To Frame off Resto in progress
