How much does a cam weigh?
Old May 27, 2004 | 03:44 AM
Shark Racer's Avatar
Shark Racer
Default How much does a cam weigh?
Just a guess...
-Steve
Old May 27, 2004 | 03:46 AM
Love My 72 and 77's Avatar
Love My 72 and 77
Default Re: How much does a cam weigh? (Pacin'California)
5 LBS. ??????????
Old May 27, 2004 | 05:22 AM
71coupe's Avatar
71coupe
Depends on the lift...
Old May 27, 2004 | 05:23 AM
munday's Avatar
munday
Default Re: How much does a cam weigh? (71coupe)
depends on the weight of the oil.
. :lolg: :lolg: :lolg: :lolg: :lolg:
Old May 27, 2004 | 05:45 AM
Les's Avatar
Les
Less than a crank???? Did I win anything????
Old May 27, 2004 | 06:06 AM
Turbo-Jet's Avatar
Turbo-Jet
about 75 kg
:lolg:
Old May 27, 2004 | 07:18 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re: How much does a cam weigh? (Turbo-Jet)
A BB cam weighs 10lb. :yesnod: BB crank weighs 70lb. :eek:
Old May 27, 2004 | 08:56 AM
norvalwilhelm's Avatar
norvalwilhelm
Default Re: How much does a cam weigh? (Jughead)
Jughead is right. I just through one on the scales and it weighed 9 pounds. :thumbs:
Old May 27, 2004 | 05:13 PM
mrvette's Avatar
mrvette
Default Re: How much does a cam weigh? (norvalwilhelm)
PHREAKING engineers.....
GENE :D :cheers: :smash:
Old May 28, 2004 | 12:30 AM
Chuck Harmon's Avatar
Chuck Harmon
about 75 kg
The real question is: Is Cam straight up or retarded? Could he possibly be advanced? Is his profile small? Is this Cam designed as a "roller" over the belt?
Chuck
Old May 28, 2004 | 01:19 AM
Shark Racer
Default Re: How much does a cam weigh? (Chuck Harmon)
about 75 kg
Chuck
I think you should ask Jughead for permission to use his username, Chuck! :D
Those are some pretty good lines there... I have to thank my lucky stars every time I read replies like these. :D Really put a smile on my face tonight.
I'm presenting on electromagnetic valves tomorrow in a technical communications class, and just wanted a statistic to drop when I talk about some of the advantages of EMV versus conventional mechanical drivetrains.
(Chuck- could you imagine driving your L-88 with 4 different sets of cam timing in it? One for 1000-2500 rpm, one for 2500-4000, one for 4000-5500, and one for 5500-7000...? What an exciting notion...)
-Steve
Old May 28, 2004 | 04:58 AM
Turbo-Jet's Avatar
Turbo-Jet
about 75 kg
Chuck
lean profile but very advanced in the art making daisy chains :steering:
[Modified by Turbo-Jet, 1:58 AM 5/28/2004]
To How much does a cam weigh?
