chromeplating/jetcoating master cylinder
Old May 28, 2004 | 07:10 AM
carl a's Avatar
carl a
Default chromeplating/jetcoating master cylinder
can't deceided if i should sterling jet coat or chrome my 73's master cylinder but the question is how do i remove the innerds to get it ready for the process?----carl
Old May 28, 2004 | 11:36 AM
shamby's Avatar
shamby
Default Re: chromeplating/jetcoating master cylinder (carl a)
TTT
I'd also be interested in how you do that.
Anyone??
Old May 28, 2004 | 02:13 PM
carl a's Avatar
carl a
Default Re: chromeplating/jetcoating master cylinder (shamby)
shamby,, my son said that theres a internal circlip holding a rubber plunger in there that pushes the brake fluid,, so i guess its a matter of removing the clip and sliding the rubber plunger out,, but dont coat the inside of the cylinder or it will leak,,,its honed...im gonna give it a try,,,,carl
[Modified by carl a, 1:15 PM 5/28/2004]
Old May 28, 2004 | 02:29 PM
Red73's Avatar
Red73
You may want to check the cost of buying a chrome master cylinder vs. having yours chromed. Check Ecklers, Summit, JEGS, etc. for pricing.
Rod
Old May 28, 2004 | 08:31 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
Default Re: chromeplating/jetcoating master cylinder (Red73)
I bought one that was already plated. It was one of the easiest things I have done. Don't remember the exact cost, but was well below $200. See Pic!
Plating takes time; usually weeks and there can sometime be disappointments.
Old May 29, 2004 | 09:06 AM
Red73's Avatar
Red73
Default Re: chromeplating/jetcoating master cylinder (OHSIXX)
Here is the link to the chrome master cylinder from ecklers:
http://www.ecklers.com/product.asp?d...5P03CD99902D21
[Modified by Red73, 9:07 AM 5/29/2004]
Old May 29, 2004 | 09:41 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Couldn't see a listing for non-power brakes. :cry
Old May 29, 2004 | 10:39 PM
LFZ's Avatar
LFZ
Default Re: chromeplating/jetcoating master cylinder (Jughead)
tuffstuff makes them for powerbrakes, but they can also be used on manual brakes...might have to do some modifications to the rod, but nothing major.
To chromeplating/jetcoating master cylinder
