Rear End?
Old May 29, 2004 | 01:18 PM
micks69's Avatar
micks69
Default Rear End?
How can I tell with the differential out of the car if the unit needs service or replacement?
Old May 29, 2004 | 10:11 PM
rob75383's Avatar
rob75383
Default Re: Rear End? (micks69)
Did it work before it was removed?
Is the case cracked or leaking?
Have you looked at the gears wear pattern?
If you're like me, and can't remember- or never knew- the correct wear pattern, take a pic and post it here.
I think there's also a way to check the lash between the ring and pinion.
The bearings might be questionable, and also the condition of the limited slip clutches too- but I don't know how to check those by eyeballin' them.
