Corey_68
close
- Member SinceFeb 1999
- LocationRepublic of Texas
Liked:665 Times in 396 Posts
I went to EVERY parts store in town I can't find anything that will match up. What flexplate are you using w/ your ZZ4 and Th400?
I replaced my Torque Convertor with one that matches the holes in the ZZ4 flexplate. I vaguely remember that the flexplate that would work with a stock TH400 convertor was about $50-60 from GM, I was able to buy a unused B&M Holeshot 2400 from a guy for $75.
Corey_68
close
I'm running a B&M 2500 stall (might be a 2400, it's been a while) but I can't seen to get anything to bolt up. Frustrating... :mad
The correct flexplate is available from Scroggins & Dickey Chevrolet phone number 800-456-0211. The part number is 014088761 it is a 14" diameter / 166 tooth flexplate. The cost was $93.51. This flexplate will allow you to use your original starter also.
BSeery
close
- Member SinceMay 2001
- LocationExiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
- Veteran Field #2CI 6-7-8 Veteran
- Veteran Field #3CI-VIII Burnout Champ
- Veteran Field #4St. Jude Donor '06-'10, '13
Liked:3 Times in 3 Posts
Just about any good GM dealership should have it in stock. If not, it could easily be ordered.The correct flexplate is available from Scroggins & Dickey Chevrolet phone number 800-456-0211. The part number is 014088761 it is a 14" diameter / 166 tooth flexplate. The cost was $93.51. This flexplate will allow you to use your original starter also.
