OFFSET TRAILING ARMS
Old Jun 29, 2004 | 10:55 AM
norvalwilhelm's Avatar
norvalwilhelm
Default Re: OFFSET TRAILING ARMS (norvalwilhelm)
Look at this old post on how to make you own offset trailing arms http://forums.corvetteforum.com/zerothread?id=551300
Old Jun 29, 2004 | 10:20 PM
lostpatrolman's Avatar
lostpatrolman
Norval, is there any difference in quality/strength between your trailing arms and these?? like It looks it would be hard to bend teh metal to make it form that arch. What are your thoughts?
Old Jun 30, 2004 | 07:36 AM
norvalwilhelm
Default Re: OFFSET TRAILING ARMS (lostpatrolman)
Weather you bend the metal of make flat turns doesn't matter. The material is only 1/8th thick so bending it just saved a few welds and make it look smoother but do it is pieces is fine.
Remember you are gaining a 3rd wall so they are stronger.
