Muncie linkage adjust
Old Jul 5, 2004 | 01:14 PM
Lasse's Avatar
Lasse
Default Muncie linkage adjust
Hello guys!
I need to adjust the linkage of the original shifter and have seen a gauge in Haynes manual. They say that it should be inserted into control lever bracket...
Is it from the inside of the car or from the underside?!
Old Jul 5, 2004 | 02:01 PM
djcwardog's Avatar
djcwardog
Default Re: Muncie linkage adjust (Lasse)
I am about to do the same thing. I think you have to go under the car and get the guage to slide in. Zip sells the guage for $3.00 (their part #ST-406).
Old Jul 5, 2004 | 02:30 PM
Lasse's Avatar
Lasse
Default Re: Muncie linkage adjust (djcwardog)
Thanks djcwardog!
I tried to fix it without the guage and I think it worked. I should take a ride tomorrow!
Old Jul 5, 2004 | 02:34 PM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
There is a drawing in the Factory manual also (at least in my '72 factory manual there is) that shows the dimensions of the gauge and how to do it. But I gotta say. this ranks right at the top of my list of POS jobs IMHO. There's just no room in the trans tunnel area. It's doable but a pain. Now if your 2 year old son has mechanical abilities..... CHarles
Old Jul 5, 2004 | 02:37 PM
Larry B.'s Avatar
Larry B.
You need to do that under the car. If you have side pipes it is easy. If you don't have side pipes it will make you consider putting them on.
Old Jul 5, 2004 | 02:45 PM
JIM's Avatar
JIM
Default Re: Muncie linkage adjust (Larry B.)
Buy a HURST, you'll be muchhappier
Old Jul 5, 2004 | 03:03 PM
Mako72's Avatar
Mako72
Old Jul 5, 2004 | 04:38 PM
theandies's Avatar
theandies
Default Re: Muncie linkage adjust (Mako72)
Old Jul 12, 2004 | 06:39 PM
djcwardog's Avatar
djcwardog
I just replied to another post (search my recent replies) and described how I used the guage - working from inside the car to just barely get the guage to slide in from the driver's side and lock up all three levers into neutral. Everything else done under the car...
By the way - Corvette Central sells the guage for $2.00...
To Muncie linkage adjust
