Need help changing to Electronic Tach
Old Jul 8, 2004 | 09:02 AM
nhlgopens's Avatar
nhlgopens
Default Need help changing to Electronic Tach
I have a 74 that had the original cable drive. I changed out the distributor with HEI and did away with the mechanical connection. Now I need assistance trying to figure out how to get the tach converted to electronic so that it's functional.
Old Jul 8, 2004 | 09:08 AM
Ganey's Avatar
Ganey
Get a 75- HEI tach
Old Jul 8, 2004 | 09:51 AM
tom102's Avatar
tom102
Default Tachometer
Easiest solution is as said above get a 75-76 hei electonic tach, It will fit right in your opening. I am not sure that your wiring harness has the connections for the electric tach, probably not. So you would have to either find an accessory harness or hard wire it yourself. I have seen a lot of tachs on ebay. Or you could order from a supplier like Zip, or Ecklers at a higher price.
Old Jul 8, 2004 | 10:14 AM
markdtn's Avatar
markdtn
Clocks by Roger can convert your mechanical tach to electronic. You could use 75-77 stuff as suggested as well, but the face won't match your speedo, and I don't like the later speedo with the KPH figures. My .02
To Need help changing to Electronic Tach
