Differential additive question
Old Jul 9, 2004 | 01:09 PM
Chumpzilla's Avatar
Chumpzilla
Default Differential additive question
Did an archive search regarding the posi additive for our differentials and noticed a couple of people did not use the additive.... however they did make sure to use GL5 80w90 gear oil.
Any thoughts on this? Do most here use the additive or are there common oils out there that can be used without having to use additive? Thanks.
Old Jul 9, 2004 | 02:26 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
you need the additive so the clutches don't stick and give you that clicking noise as you make turns
Old Jul 9, 2004 | 02:46 PM
comp's Avatar
comp
add if you don't have a posi. it doesn't hurt
Old Jul 9, 2004 | 03:10 PM
tom102's Avatar
tom102
Default Posi additive
I would strongly recommend using the GM posi additive , it is cheap insurance and keeps the clutch's quiet.
Old Jul 9, 2004 | 06:15 PM
R. Bruno's Avatar
R. Bruno
To Differential additive question
