Rear Springs
Old Jul 11, 2004 | 08:19 PM
jeromeunderwood's Avatar
jeromeunderwood
Default Rear Springs
Hey guys, anyone replaced their rear springs? I think mine is in need!
Old Jul 11, 2004 | 08:39 PM
1970 Dave's Avatar
1970 Dave
Yes--you will need to decide if you want to maintan the stock 7 or 9 spring leaf or go to the new composite spring. Everything I have heard, these composite springs are a more comfortable ride and with the right shocks help in the cornering. Not a real bad job as far as "Vette jobs" go.
SEMPER FI--1970 Dave
Old Jul 12, 2004 | 10:42 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Old Jul 12, 2004 | 10:45 AM
killervette666's Avatar
killervette666
I recently replaced mine and it was very painless, i did have to cut the spring bolts though, i just couldnt find a wrench to fit into that little box and go on top of the bolt to stop it from turning when trying ot take the nut off. I got the gymkhana spring from VBP with kyb gas-adjust shocks, i dont care much for ride quality so i opted for the performance and handling of the gymkhana spring.
Old Jul 12, 2004 | 11:13 AM
mandm1200's Avatar
mandm1200
The best way to get a wrench on the top of the spring bolt is to jack up the trailing arm a little. This will position the bolt so that a wrench can be put on it. After the wrech is put on, release the jack and use it to jack up the spring to release the force it puts on the nut.
I have the 330lb composite spring, which replaced the gymkhana spring. The ride is much better and not nearly has harsh. Like many others, I had to use longer spring bolts to set the height.
Mike
Old Jul 12, 2004 | 01:27 PM
Kid Vette's Avatar
Kid Vette
If you decide to go with a composite spring, go with VBP. You won't have to deal with the height issues caused by the TRW design spring.
Old Jul 12, 2004 | 02:46 PM
VBP's Avatar
VBP
St. Jude Donor '07,'13
Jerome,
Give me a call, Corvette Forum members always get a discount with us. 800-237-9991 or tony@vbandp.com We have plenty in stock.
Tony
VBP
Old Jul 12, 2004 | 03:16 PM
Disco_Mike's Avatar
Disco_Mike
Tony!
Thanks for the post.
Ill log you email in my address book and give you guys a call when Im ready to rebuild my suspension!
Thanks for supporting the forum!
Old Jul 12, 2004 | 03:25 PM
gkvetteuno's Avatar
gkvetteuno
Veteran: National Guard
Unless you have broken leaves, you might want to install a set of KYB Gas-adjust shocks. I used them on my 71 with the original spring and couldn't believe the difference. Restored the normal ride height and handled great. Best improvement for the money I've made.
Old Jul 12, 2004 | 08:12 PM
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
To Rear Springs
