suspension question
Tire lean in/out is called camber. Wheel camber is obtained by adjusting the eccentric cam and bolt assembly located at the inboard mounting of the strut rod. For the wheels to lean in/out there must be play somewhere in the strut rod assembly mechanism.
The outboard mounting location of the strut rod is the "shock mount bolt" (the lower bolt your shock absorber is attached to). The inboard mounting location of the strut rod is the long bracket attached to the bottom of your differential. The eccentric bolt is at this inboard location.
Has someone recently worked on your rear suspension, especially the strut rods? If so, there are washers that MUST go into the strut rod bushings.
If the suspension has not recently been worked on, it is likely the bushings in the strut rods have deteriorated and that is what is allowing the camber change.
Are your strut rods straight? Some "mechanics" heat and bend the strut rod in order to achieve alignment. This is not good practice, but may be an indication that they couldn't loosen the (shock mount /eccentric cam) bolts to do a proper alignment. If they couldn't loosen the bolts, then the bushings may also be deteriorated.
After the strut rods are repaired, the car will need a rear wheel alignment.
But regardless of what you do, when you have the car realigned, and you eventually will, make absolutely certain that who ever does it is intimately familiar with how to do the rear of these cars. This was a major deal when I had mine done, and I now realize that most alignment techs are clueless about these cars. But once it was done right, I realized that of the 3 sharks I've had, this is the only one that was aligned correctly. It really handles like a different car compared to the other two.
TTT
