Mod Question - Rocker Switch Controls
Old Jul 12, 2004 | 01:00 PM
80TexasC3's Avatar
80TexasC3
"Rodstoration &am p;quot; In Progres
Default Mod Question - Rocker Switch Controls
There has been a lot of inspiration to rebuild my 80 as "my car" vs doing it the "proper restoration way"... One of the mods I'm in the middle of is converting the ashtray/lighter compartment into a rocker switch panel (under the door). Current design is to have rockers controlling (via relays):
Engine Fans
Fuel Pump
What other suggestions do you have? One suggested the ignition power...
Thanks for the ideas...
Old Jul 12, 2004 | 02:16 PM
chicken's73sting's Avatar
chicken's73sting
Ya also might wanna put one in there for Nitrous it'd be pretty sweet to flip that little cover open and then arm nitrous and then take off. hehehe. well thats just my opinion.-Danny
Old Jul 12, 2004 | 02:26 PM
CrossedFlags77's Avatar
CrossedFlags77
I was hoping this topic would come up again because I couldnt find it after the forum switch. Here are pictures of the small panel I made.
Old Jul 12, 2004 | 02:30 PM
norvalwilhelm's Avatar
norvalwilhelm
I don't believe in using switches to control power. I like relays, they are about $5, reliably switch 30 amps and the only thing I use switches for is controlling the relays. I have a whole bank of relays and trouble shooting is very simple.
Old Jul 12, 2004 | 04:16 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
Don't our 80's have mechanical fuel pumps?? How's a switch gonna control that?
My brother is a screen printer and is planning on making a new idiot light cover to replace the seatbelt warning light. Just haven't figured out what to have him make me. He will have to make about 10 of them. A couple will be worthless, to set the printer correctly, but there should be about 5 or 6 extras. If I come up with something good I'll share the spares.
Old Jul 13, 2004 | 11:57 PM
80TexasC3's Avatar
80TexasC3
I am definitely interested! Keep me posted... Ed
Old Jul 14, 2004 | 12:02 AM
80TexasC3's Avatar
80TexasC3
Have built a relay box that will mount in the engine compartment on the firewall (just to the left of the wiper motor. Switches under the ashtray cover will control the relays. Plan to tap power for the switches from the old lighter and use it's ground as well (rockers in parallel). This will allow me to have to pass only a limited number of wires into the engine compartment and to the relay box.
Ak. Mal, my 80 has a mechanical fuel pump also... I'm going to have the wiring done and ready to convert it to an electric pump in the near future.
Ed
Old Jul 14, 2004 | 04:15 AM
pillowmeto's Avatar
pillowmeto
When i do my rebuild i intend to use the ashtray in my 76 as the switch center for fuel pump, fans, water pump, nitrous arming, and i already have converted the lighter into a kill switch
MAtt
Old Jul 14, 2004 | 04:51 AM
mrvette's Avatar
mrvette
A few pix of my console in the '72 there on my site, the switches are pretty close to that even now.....I have the HVAC working through later model vacuum solenoids/relays, to actuate the dash pots for airflow, and the black button in the midle is a built in garage door opener, works only when engine is running, built in remote also controlls the computer for anti theft, ....
also the lights are for the 2 injector banks, and the spark layout in sequence....and F pump, and service engine....
one of the first things I did when ditching that old mechanical crap.....went through a complete overhaul and final tune up on the wiring some 3 years ago....
GENE
Old Jul 14, 2004 | 07:00 AM
saudivette's Avatar
saudivette
I used to have a 1984 Caddy that I shoehorned a 500cube Caddy big block into. I found a (very appropriate) sticker that I stuck on the glovebox door:
"Get in, sit down, shut up, HOLD ON!"
I dunno if you would have enough room to be able to write that clearly on the seat belt warning lense, would look good tho....
Old Jul 14, 2004 | 09:49 AM
80TexasC3's Avatar
80TexasC3
MAtt
Thanks! did you hook the kill switch to a relay that basically spliced your BATT (power to the distributor)?
Old Jul 14, 2004 | 10:54 AM
Ak. Mal's Avatar
Ak. Mal
Another switch I'm going to install is on the neutral safety switch on the clutch. When I bought my car, the fu(ktard previous owner cut the two wires going to the relay and connected them, meaning that I didn't have to press the clutch in to start the car. While wiring it back up, I realized that it didn't matter which wire went where, just as long as when the clutch was pressed in, the relay would connect the two wires. I plan to install a switch on one of the wires as a kill switch. By not allowing any signal through one wire, it is impossible to start the car.
So, tucked up under the dash I plan to install that switch.
To Mod Question - Rocker Switch Controls
