aerodynamics question
Old Jul 15, 2004 | 05:07 PM
  #41
HunterRose's Avatar
HunterRose
You'd probably have to do something similar to what they did for the Lotus Motorsport Elise, which was to add a panel that latches between the rear buttresses and smooths out the flat area. That way you can take it off when cruising around (keeps original lines), or pop it in and go racing!
I saw one of these spin off the track and actually LOSE the panel! Banged it up pretty bad since it was made of fiberglass! Driver was pissed. The car was on of only 5 in the US at the time.
Cheers,
Tony
Old Jul 15, 2004 | 06:23 PM
  #42
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
I can make a fiberglass bubble that I could Attach to the C3, throw a system of latches and weather stripping. I just dont know how I would put in a rear window in it.
I was wondering what kind of effect a rear wing would have to the air flow around the rear drop of the panel
Old Jul 15, 2004 | 10:45 PM
  #43
jetech's Avatar
jetech
Maybe a set of Vortex Generators just aft of the T tops. At speed maybe the boundary layer of air would be forced over the flat area.
If some some type of spoiler is added it might even be possible to increase down force.
Where's a wind tunnel when you need one
Old Jul 16, 2004 | 09:17 AM
  #44
ZD75blue's Avatar
ZD75blue
A video camera mounted on the dask/t-top bar looking back through the rear window with some yarn taped might show you what your looking for...
Old Jul 16, 2004 | 10:10 AM
  #45
Guru_4_hire
Cruise-In V Veteran
what exactly would I be looking for?
Old Jul 16, 2004 | 10:39 AM
  #46
HunterRose's Avatar
HunterRose
You wouldn't have to put a window in it, just have louvered slots in it so you can see (like those sun-shields they used to put on camaros and the like).
Cheers,
Tony
Old Jul 16, 2004 | 10:57 AM
  #47
Guru_4_hire
Cruise-In V Veteran
I think the visibility is already crappy enough thank you. I think I could just cut out a flat part and put in some plexyglass
Old Jul 16, 2004 | 11:56 AM
  #48
jetech's Avatar
jetech
What ZD75blue is referring to is a method used to visually see what the airflow characteristics are over a given surface.
Short lengths of bright yarn (1/2" to 2") are taped on the surface in a grid with around 3"+ spacing.
The vehicle is then operated at speed and the yarn pattern is recorded, what you are looking for are areas of turbulent airflow (where the yarn strings are blown sideways or forward).
It would be ideal to get the airflow just aft of the rear window (77 and earlier) to be neutral with no turbulence.
I suggested Vortex Generators because they are used effectively on aircraft to modify airflow characteristics by creating a spiraling airflow that reduces turbulence.
I was thinking it may be possible to spiral the airflow over the rear deck area reducing the turbulence behind the rear window.
Old Jul 16, 2004 | 12:18 PM
  #49
jetech's Avatar
jetech
Here is a link that explains how they work. http://www.microaero.com/pages/v_howvgswrk.html
They are easy to make but expensive to buy.
Old Jul 16, 2004 | 02:23 PM
  #50
Guru_4_hire
Cruise-In V Veteran
What would these vortex generators look like?
Old Jul 16, 2004 | 02:25 PM
  #51
Guru_4_hire
Cruise-In V Veteran
I would be willing to apply these vortex generators on my C3. It would be interesting for some before and after tests.
Old Jul 16, 2004 | 04:04 PM
  #52
jetech's Avatar
jetech
Vortex Generators are an "L" or "T" shaped piece of metal or plastic, they are about 1" long and 1/4" tall. The front vertical edge is rounded over and the aft edge is left square.
There is a specific layout for them and I have it somewhere, so if you are interested I will try to find it.
You can do a web search for Vortex Generators to get a better idea of what they look like.
I made some for my plane by bending thin aluminum strips into an "L" shape and then cut them to length and rounded the front edge.
Double sided tape can be used to hold them in place for testing.
Go to the link I posted above, then go to Gallery and then to the Cessna A185F picture. The green stripe is a layout guide so you can get an idea how the leading edges are closer together than the trailing edges. The generators that this company sells look to be about 3/8" tall. Check out some of the other pictures.
Old Jul 16, 2004 | 04:23 PM
  #53
ZD75blue's Avatar
ZD75blue
The other way of creating them is to leave a bulb on the trailing edge of an under body panel... You get it to spiral out, say from right in front of the rear tire. Lets the car suck down a little more because the tire is spinning in clean air.
Old Jul 16, 2004 | 05:22 PM
  #54
hunt4cleanair's Avatar
hunt4cleanair
So I have been able to find out what the coefficent of drag is. But I havent been able to find out what the frontal area is.
Does anyone know what the frontal area of a C3 specifically a 73 is?
The coefficent of drag is .40
I posted this a while back and may be repeating but not about to scan three pages of babble.
Early C3 cd (pre 78) = 0.50
Late model C3 (1978+) = 0.43
Old Jul 18, 2004 | 03:35 PM
  #55
Guru_4_hire
Cruise-In V Veteran
How can it be that high?
Old Sep 19, 2004 | 01:09 AM
  #56
lostpatrolman's Avatar
lostpatrolman
Sorry to bring an old thread up, but I was thinking about something. Would removing the rear window and cracking the windows down a bit help the coefficeint of drag for our cars? Wouldnt it eliminate that large area of stangnant air causing less drag and cleaner air flow?
Old Sep 19, 2004 | 04:50 PM
  #57
lostpatrolman
Old Sep 19, 2004 | 06:02 PM
  #58
Twin_Turbo's Avatar
Twin_Turbo
it would make things even worse, the whole interior would be a big air trap.
Old Sep 19, 2004 | 07:37 PM
  #59
1979toy's Avatar
1979toy
According to "The Corvette Black Book" the 1980 model had a drag coefficient of .443 which was an improvement from the 1979 Corvette equiped with the optional spoiler package of .503. The same referance states that there was a 15 percent drag reduction with the installation of the optional spoiler package on the '79. That should put the non spoiler equiped '78 and '79 at about .575. I can not find any numbers for earlier models.
