brake bleeding.
Old Jul 15, 2004 | 03:04 PM
i885744's Avatar
i885744
Default brake bleeding.
I'm fairly new to working on corvette's and everyone is mentioning this "weird brake bleeding order" I just installed 4 new calipers and a new master cylinder. I filled the cylinder with dot 3 and bench bled it prior to installing it in the car. i filled it up again and am now ready to bleed the brake calipers themselves. What is the proper order? Is there anything weird about bleeding corvette brakes or can I just bleed like a normal car? Thanks, Mike
Old Jul 15, 2004 | 03:19 PM
kermit1654's Avatar
kermit1654
Just learned the correct order myself.
Here is the correct bleed order
Driver Rear Inner
Driver Rear Outer
Pass Rear Inner
Pass Rear Outer
Driver Front
Pass Front
Good luck.
