New Guy
Old Jul 16, 2004 | 11:24 AM
74Thrasher's Avatar
74Thrasher
Default New Guy
Hello everyone,
My name is Colin, and I just picked up a '74 Stingray in Burnt Orange the other day. Prettiest car I've ever owned, which doesn't say much. It's in decent condition, still needs a lot of work though, to be sure.
I have seen some really nice C3's here so far, and hopefully one day my car will be in great condition as well. I have always loved Corvettes, and I found one that was at too good a price to pass up, so I just up and bought it.
Any recommendations on what to go at first? The interior or the exterior or the engine?
Thanks,
Colin
Old Jul 16, 2004 | 11:31 AM
MILO's Avatar
MILO
Welcome!!
I've always gone for reliabilty first then cosmetics. Keep reading the different posts even if they don't apply. You'll be amazed how you pick up things.
Good Luck.
Old Jul 16, 2004 | 11:39 AM
Jack71's Avatar
Jack71
Welcome!
I would start on the inside and work out.
Drivetrain
Suspension / Steering
Interior
Exterior
Try and keep it on the road as much as possible. Long periods of down time can be hard to cope with & stay motivated.
Old Jul 16, 2004 | 11:50 AM
comp's Avatar
comp
welcome
Old Jul 16, 2004 | 11:54 AM
Wendell Allen's Avatar
Wendell Allen
Depends on a couple of things. First, how often will you be driving? Do you have a significant other who will be in the car, and if so, how often?
Basically what I've done with all three of the sharks I've owned is to prioritize according to what makes the car livable for my wife and I both since she's in the car almost as often as I am.
So basically that involves first making sure the car is mechanically road worthy. Then comes the legal stuff like tags, inspection, and insurance. Then I've mostly worked on the interior since no one likes driving a trash truck day in and day out. After that it's just a matter of taking care of the optional stuff like A/C, the cruise control, and stereo work.
Others here may disagree, but I strongly suggest that you get an assembly instruction manual from MidAmerica, as well as the factory service manual. The factory manual is leagues above the other aftermarket manuals. Between those two manuals, there won't be much you can't do on the car, and you'll go to bed at night knowing it's been done right.
And finally, I also suggest you hook up with other shark owners in your area. The guys I've met here in Houston have really been some strong moral support as I've worked through my sharks, and they've become some very good friends as well.
Good luck, and welcome to the wonderful world of Vetting.
Cheers!
W
olouieo's Avatar
olouieo
Originally Posted by Jack71
1.Drivetrain
2.Suspension / Steering
3.Interior
4.Exterior
Welcome. Have fun with your new toy, and enjoy.
Old Jul 16, 2004 | 11:56 AM
ACECO's Avatar
ACECO
St. Jude Donor '04 & '05
Welcome to the insanity!
I too would would go for reliabilty first and worry about making it pretty after that. Too many people do it backwards IMHO.
Good Luck w/the new toy!
Old Jul 16, 2004 | 03:25 PM
RMVette's Avatar
RMVette
Welcome!
Old Jul 16, 2004 | 03:40 PM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
Hiya Colin
Old Jul 16, 2004 | 04:26 PM
Tiredol74's Avatar
Tiredol74
I would add check out mechanical systems first...like brake, fuel, cooling, chassis, drivetrain, etc. to be sure. Good chance will run into some electrical probs enroute.
Old Jul 16, 2004 | 08:44 PM
markdtn's Avatar
markdtn
Cheers!
W
I couldn't have said it better.
Old Jul 16, 2004 | 11:42 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Welcome to the Corvetteforum!!!
Old Jul 17, 2004 | 02:58 AM
Pauld's Avatar
Pauld
and welcome to the forum
Old Jul 17, 2004 | 02:24 PM
74Thrasher's Avatar
74Thrasher
Thanks for the replis guys, I am happier everyday with my purchase. Now to the first question I have:
This morning the car started backfiring/misfiring, I'm not exactly sure which one it is. When I lay off the gas, it sounds like a small knocking noise. When I get on the gas, though, a puff of smoke comes out of the carbeurator. Anyone have any ideas what could be causing it?
Old Jul 17, 2004 | 03:22 PM
LakotasRose's Avatar
LakotasRose
and welcome to ''Shark Infested Waters''!!
Old Jul 17, 2004 | 03:23 PM
LakotasRose
Sounds like the timing is off.
Old Jul 17, 2004 | 07:45 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Welcome to the forum and congrats on your Corvette purchase
I always go for reliability and safety 1st, then make it prettier
Old Jul 17, 2004 | 08:57 PM
crazcorkath's Avatar
crazcorkath
Was the car being used when you bought it? First thing I would do is change all the fluids--oil, tranny and rear differential. Things will definitely pop up as you drive the car, but changing these fluids you will at least know that they in fact have been changed.
I would definitely concentrate on mechanical first, because it can look pretty, but it has to go, if you know what I mean. Hope this helps you and welcome!
Old Jul 17, 2004 | 09:00 PM
crazcorkath
Since it's a '74, if it has the original distributor, it will have points that can be adjusted. It could be a number of thins though. At$1.50 per plug, I would change the plugs(not much money) and it will give you an indication of how the engine is running. The problem could be carburetor or timing though.
To New Guy
