Smart Struts Squeak
Old Jul 16, 2004 | 02:17 PM
jamesx0's Avatar
jamesx0
Default Smart Struts Squeak
I just got VBP's Smart Struts in the mail today. When I move the strut rods, the poly bushings squeak. The bushings look impossible to get out without hacking. What's the best way to grease up the bushings?
Old Jul 16, 2004 | 02:24 PM
Fevre's Avatar
Fevre
Might try taking them off and soaking the ends in syn gear lube. They also may have graphite in them which will release as they break in and quite them down.
comp's Avatar
comp
all the poly bushings i've seen do, i haven't used the poly-graphite one's
on anything yet
Old Jul 16, 2004 | 03:17 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
If you remove the sleeve the bushings will pop out. Call VBP and see if they'll send you some grease.
Old Jul 16, 2004 | 09:05 PM
75 Hot One's Avatar
75 Hot One
I've found that if you spray the ends of the bushings with molybdenum disulphide spray lube, the lube seeps in and stops the squeak. Respray if first spray doesn't work. This saves taking the struts apart.
To Smart Struts Squeak
