Holley 650 DP mech. secondaries
I'll take pics tomorrow if I need to.
There are three vacuum ports on this carb only - the rear port for you power brakes and accessories, then just the two vacuum ports for timed and manifold vacuum for your distributor advance. Obviously, plug them up if you are not using them.
Any change you can take a picture for me? I have the rear one hooked up....as well as PCV.
From the rear vacuum port I have my brakes connected as well as all vacuum controlled accessories (headlights, wiper, etc,), from the front timed port I have my vacuum advance connected, from my front manifold vacuum port I have my electric choke connected. That's it.
Take some pics. I'll try to get some pics of mine.
I've rerouted some vacuum lines and everything on mine seems to work.
My (vacuum controlled) heater controls do not, but; I haven't dug into those yet.
All other power accessories and headlights are AOK.
I've got PCV connection going to the breather, not the carb.
Sounds like mine is hooked up similarly to the other guys.
go to photobucket.com
get an account (it's free).
upload your pictures and then you can cut and paste the [IMG] section here to allow us to see the pics.
That being said, if you can get a couple of pics to see exactly what vacuum lines you're talking about, then maybe I can help. (I'll try anyways).
THANK YOU! Uploading pics as we speak
It may be for the vapor canister.
(pollution device that filters gas fumes).
When I got mine, there were some lines like that that were just hanging or sitting with a bolt in them.
I removed them and put vacuum caps on the connectors.
Take a pic or to from a little farther away and maybe above so I can see the "big picture" so to speak.
I noticed your block is orange. I didn't think they painted them that color in 79. Mine is the crappy light blue. Has your motor been replaced/rebuilt?
Car runs fine without them.....I'll just cap them and assume they're for something I no longer have. Obviously more of a "fun" car than a perfect "numbers matching" car.
What kind of heads? Stock modified?
What intake you got on there?
I am hoping to do some mods to mine, but; not as soon as I hoped.
I just found out that my rear wheel bearings are bad. $400+ and that is if I remove them and send them off. Sheez!
I also have a bad tire.
Of course, they are very old and not made anymore, so; I'll have to get 4.Guess the intake and headers get to wait a few more months. . .
Mine is supposed to be a 24K mile car, but; I'm beginning to wonder.
I bought mine as a fun car as well, though, so I'm not losing any sleep over it. I will be modding.
Over the winter I plan on removing the engine and replacing all of the gaskets and clean it up / paint it as I have a couple of oil leaks. Then while it's out, I'm going to detail the engine compartment.
I've been spending all my free time on the brakes. Hopefully today I'll get my last brake line via UPS and install it trouble free (ha!)....and then i can at least drive it. Already have paint for it to repaint it this fall.....paint is not in that bad of shape....but not like it should be...lots of orange peel, etc....
At some point I"ll pull the intake....clean it up and paint it, or I may just replace it.....
Tires on the front don't match the ones in the back.....but for now, it's not a priority. I just want it driveable! NEXT YEAR....I keep telling myself.
I have one soft spot in the frame that needs help.....that'll be a spring fix as well. Then, FOR SALE!
But it's that initial start that has me worried. I give it gas and it stutters as if it's going to flood. Soon as it hits about 2k rpms it sounds great. Pedal to the floor and the secondaries open up and it sounds like a beast...but if I don't keep it about 2500rpm for about 30 seconds it will sputter and die.
Any thoughts?
