68 Temp. Sending Unit Part #?
Old Jul 18, 2004 | 05:08 PM
rparkervette's Avatar
rparkervette
Default 68 Temp. Sending Unit Part #?
Can anyone give me the part number to an accurate temp. sending unit for 327 auto with a/c. Napa, Crow Burlingame, Oreilys. Thanks.
Old Jul 18, 2004 | 05:13 PM
Larry B.'s Avatar
Larry B.
"lectric limited" is the only accurate one that I know of.
Old Jul 18, 2004 | 10:17 PM
R1234's Avatar
R1234
Try a Wells TU5 sending unit. Should read about 700 ohms at room temp. You can get them at most auto parts stores.
Old Jul 18, 2004 | 10:26 PM
bqce's Avatar
bqce
I agree, call Lectric Limited. I had heck getting a sending unit that matched up with the stock gauge and the ZZ4 in the 74 - they got me straightened. out.
Old Jul 19, 2004 | 12:37 PM
rparkervette
Do I go in and ask for exactly that? I would think the teenagers behind the counter will look at me and go "whatever dude". Do you by chance have a part number or model reference. I may have to order from lectric, but I was wanting to get it today.
Old Jul 19, 2004 | 03:13 PM
markdtn's Avatar
markdtn
Not to be smart, but with a 68 engine why not just go into NAPA and ask for your application? The problems come in with swapping later engines in early cars, then use an 82 sending unit. They have smaller bosses in the heads than the early engines.
Old Jul 19, 2004 | 04:33 PM
Larry B.'s Avatar
Larry B.
If you get a GM 68 replacement A/C delco sender, it will be WRONG. application won't do it for you.
Old Jul 19, 2004 | 10:56 PM
rparkervette
Ok , earlier its said to be 700 ohms at room temp. Are all (68 to 82) our temperature Gauges set to use this? I've tried once last year and ended up with something close. It went to a late 80's chevy truck. If one is reading to high by about twenty degrees, can I add a resistor to it to drop the reading?
Old Jul 19, 2004 | 11:08 PM
62fuelie's Avatar
62fuelie
If you add a resistor you may well end up with an accurate reading in one range and very inaccurate in another. Remember that the real purpose of the gauge is to warn you of an overtemp condition, not to give a certain reading at normal temps.
Try the Wells TU5 from Autozone. They cost $6. Mosy people who try them report good success. I discovered these about 5-6 years ago and started recommending them on the NCRS board. Since then, probably 2 dozen people have emailed me to tell me the TU5 worked in their car. All the Vettes from 57 to about 76-77? use the same sender. It will work with the 56 also, but the wire connector is different.
Old Jul 19, 2004 | 11:33 PM
R1234's Avatar
R1234
The Wells TU5 is what I am using in my original 327 and it has been reading accurate. I read about it on the NCRS board. I also had to replace the pin type connector on the wiring harness with a mushroom head type connector.
Old Jul 20, 2004 | 12:38 AM
62fuelie's Avatar
62fuelie
Yeah, I forgot the later cars also use the pin type connector, similar to the 56. I should have said that the Wells unit will fit 57-67 and 56, 68-7X "with a little modification".
To 68 Temp. Sending Unit Part #?
