Bouncing Volt Meter
Old Jul 19, 2004 | 12:04 AM
dogr74's Avatar
dogr74
Default Bouncing Ammeter
While driving down the road at a constant speed, my amp meter constantly bounces from about 2 to 15 amps at about 1 second intervals. It doesn't bounce when there is some current draw from something like the brake lights, head lights, etc. I replaced the voltage regulator internal to the alternator a while back but it didn't seem to help. Any ideas?
Last edited by dogr74; Jul 19, 2004 at 06:40 PM. Reason: Was thinking amps but typing volts
Old Jul 19, 2004 | 08:45 AM
motown 71's Avatar
motown 71
ttt
Old Jul 19, 2004 | 02:33 PM
Missileman's Avatar
Missileman
If your actual voltage reached 2V, you would know it because that will not support the coil. Also depending where you connected the voltmeter, it should not show below 12V because of your battery. It sounds like your voltmeter is defective. At constant speed with no accessories on the alternator makes max. voltage. Your voltmeter gets this high voltage and is being overdriven. When you turn on an accessory (lights, etc.) alternator voltage decreases slightly, no longer overdriving the instrument. Swap it out or change the connection location if it is an aftermarket unit.
Old Jul 19, 2004 | 06:44 PM
dogr74's Avatar
dogr74
Default Oops... Amps not Volts
Missileman,
Thanks for the reply. I agree with your logic but made a mistake in my post. Its amps not volts... daa.
Old Jul 20, 2004 | 11:08 PM
Bobbyg75's Avatar
Bobbyg75
Default Ammeter bounce
Maybe a coil?
Old Jul 21, 2004 | 11:20 AM
79ls1's Avatar
79ls1
Sounds like a loose connection or bad ammeter or wire to me.
Old Jul 24, 2004 | 09:17 AM
dogr74's Avatar
dogr74
Well, its not the coil or condensor (I put on new ones and the problem didn't go away... got a new Pertronix coil out of the deal though!). The bouncing is too regular for a loose wire and also ocurs when parked running at RPM's >3000. Sounds like checking out the alternator is the next option unless anyone has any other ideas.
Old Jul 24, 2004 | 11:31 AM
Vmo's Avatar
Vmo
Sounds like the alternator to me, got one you can swap in?
Old Jul 25, 2004 | 09:32 AM
Bobbyg75's Avatar
Bobbyg75
Toss mine on to test the alt theory. Only takes a few minutes and its a quick way to troubleshoot.
Old Jul 25, 2004 | 09:51 AM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
As strange as this may sound, check all of your connections at the horn relay.
Old Jul 28, 2004 | 05:39 PM
dogr74's Avatar
dogr74
Default Case Closed
The problem was the alternator. I had it tested and it showed a dead short even though I haven't had a weak battery. Had it rebuilt by a local auto electric shop and all is well.
Old Jul 28, 2004 | 06:19 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Glad to hear you got it fixed. Now if I can just remember this if it happens to mine. Thanks for posting your findings.
To Bouncing Volt Meter
