What do you guys think?
I've got a 1979 Stingray (as if you couldn't tell by my name), and I was just getting ready to start modding my car.
I've found the entire setup I'm going to go with. It's an Edelbrock system with a Torker II intake manifold, Performer RPM heads, a cam/lifter package, I've got pushrods on my list, gasket set, new valve/everything covers, all that. It's under Torker II package under Power Package Concepts at Edelbrock.com
I was wondering something else. What type of rockers come on a '79 Stingray stock? The pushrods I'm going to order, unless I find out something different, will work with the stock rockers. I'm just wondering if I need to upgrade the stock rockers for steel/aluminum roller rockers, or if the stock ones will hold up pretty well. Thanks for any help guys!
EDIT: I was also wondering if I would need to get a better harmonic balancer too? Or should the stock one be good for the job?
Welcome to the Forum.
But if you want to do it right from the start, buy a GM Performance Products ZZ4 and stick it in there!
Think that is an alum head 427 bb eng, if you got that then you do have a little more power than a L48.
So do you guys think this engine is honestly worthy of being built up? Or should I just start with a short block and build it up?
Oh yeah, glad to have you here on the forum.
I'd work on the induction, exhaust, and ignition systems to start and go from there.
Do you still have smog checks for your year? If not, go with headers/true duals, performer or RPM intake, rejet the qjet, and recurve the distributor along with better coil and wires.
Good luck,
Greg
