Undercar Chambered Exhaust ?!?!?
Old Jul 22, 2004 | 08:22 AM
carl a's Avatar
carl a
AS FAR AS THE HANGERS GO,,, I USED JET COATED CLAMPS AROUND THE PIPE AND A JET COATED ANGLE BRACKET(SOLD AT CAR QUEST FOR HANGING EXHAUST SYSTEMS) AND DRILED AND TAPPED 2 HOLES IN THE CROSSMEMBER-- YOU HAVE TO MOUNT THE CLAMPS WITH THE NUTS FACING UP BECAUSE THEY WILL BOTTOM OUT OVER BUMPS IN THE ROAD
Old Jul 22, 2004 | 08:31 AM
nhlgopens's Avatar
nhlgopens
Originally Posted by Stewart's74
The best part of the Chambered pipes is nailing the throttle under an overpass They scream!
Oh yeah - baby! I love my chambered system! I had the most fun blasting through a tunnel in Wheeling W.VA. Down right obnoxious!
74 L-82 Modified
Old Jul 22, 2004 | 09:40 AM
brystheguy's Avatar
brystheguy
Originally Posted by Corvette ED
My question is do the pipes bottom out and hit the ground at all? I installed an Allens true duals on my 75 and I am not happy with the fit. They hit the ground under the rear spring if I hit a dip in the road.
I haven't had any problems yet. My pipes are probably only a half-inch below my rear spring. Are yours farther than that?
