QJet question.
Old Jul 22, 2004 | 02:00 AM
Disco_Mike's Avatar
Disco_Mike
Default QJet question.
Can I use idle mixture adjustment screws from an older style QJet to replace the 'D' shaped ones on my 79?
Old Jul 22, 2004 | 09:34 AM
Steve's74's Avatar
Steve's74
The short answer is yes. But the proper tool to adjust your style of mixture screws is also available from most tool suppliers (Mac, Snap-On) fairly inexpensively.
Steve
Old Jul 22, 2004 | 09:43 AM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
even at most parts stores...only about $10 or $15
Old Jul 22, 2004 | 10:03 AM
killervette666's Avatar
killervette666
, i went to my local pepboys and they had a carb adjusting set, with a special screwdriver and attachments to fit any carb, the screwdriver had a cool cable that let you tune out the screws without bending over
Old Jul 22, 2004 | 02:22 PM
Disco_Mike's Avatar
Disco_Mike
Since the adjustment tool is available, I think Ill go for it.
do you know the name of the tool.
I dont want to go to the parts store and ask for the doohicky to turn the Idle screw things.
Old Jul 22, 2004 | 04:36 PM
comp's Avatar
comp
tell them you need the idle screw adjuster for Q-Jets
To QJet question.
