???Dimensions: wheel/tire/back-spacing/rear-end
My original plans were for a complete 'back-half' (narrowed 9", new frame rails, wheels tubs, 33" x 15 slicks, ladder-bar/4-linkwith coil-overs, fuel cell, cage, interior tin-work, etc.), but the cost of that, coupled with a new motor is
making this a very long-term goal, at-best.
A few days ago, a buddy said:
"Why not take the original 10-bolt rear-end from your '79 Z28 (I replaced it with a bullet-proof 12-bolt years ago), that already has a posi 4.56s, whack all the mounting tabs off it, have the local chassis-guy build you a 4-link/coil-over suspension using it (the 10-bolt) and the existing frame rails, fuel tank, etc., and while he's at it, have him install a decent cage, too.
I got enough spare parts (block, crank, rod/piston assemblies, cam, cylinder heads, intake, etc.) laying around my shop that we can put a 400+ HP 355" SBC together for cheap;
it'll make as-much, if not more, HP than the one in your Z28 (which runs high-12s), run on pump-gas, turn easily to 6400 RPM, and won't hurt itself in the process.
You've already got a spare THM400 that is 'built', ready-to-go, along with an 8"/4000 RPM stall converter.
You don't want to try changing the Earth's rotation; you just want to run good, consistent mid/low 12s without busting the I.R.S., and without spinning the tires.
Figure-out what wheel-offset you'd need, using the stock-width '79 Z28 housing, to get 30" x 10.5" slicks (13.5" section-width) into the wheel-openings, without rubbing the inner wheel-tub....."
Originally, I thought: "No; I want a REAL race-car", but it did get me thinking about this possibility.
I guess my questions to you guys with very big rear tires are:
#1: What are the dimensions, in inches, of your tires (anybody running 30" tall Pro-Street-style tires?) Height, width, section-width, etc.
#2: What is the side-to-side dimension of the stock I.R.S. (wheel-mounting surface to wheel-mounting surface)?
I am going to my storage facility later today to measure this dimension on the 10-bolt...
#3: What wheel-offset/back-spacing would I need to stuff 30" x 10.5" tires, with a 13.5" section-width (cross-section) tire into a C3, if the trailing-arms and other I.R.S.-bracketry weren't a factor?
#4: Any 'other' questions I've over-looked?
My 'original', whole-hog plan would've cost close to $10k at the chassis-shop, and another $5-$7k for the motor;
my buddy is thinking that this 'modified' solution would cost only $4k at the chassis shop, probably another $1k in wheel and tires (both front & rear), and maybe as little as $2500 in the SBC.
In other words, "IF" this works, I can go racing for half of my 'original' plan...
THANKS IN ADVANCE:
any thoughts, ideas, and recommendations are greatly appreciated.
Opting for TOM'S 12-bolt set-up was considered, but I'd still have all the splined joints, alignment issues, U-joints, geometry-problems, etc.
I'm guessing that I'd need to find an 'early' C3 iron rear-end ('pre-80), and then spend a few grand...
and at the end of the day, I'd still have a rear-end that is made for cornering, not transferring power in a straight-line.
This Vette'll never see the road again;
it is 'well-used', and I bought it specifically for this application.
This'll become my 'primary'-car at the track, 'specially if/when I relocate to compete in the various 'Corvette Challenge Series'.
Raising the rear of the car is not a problem for clearence:
Vetteman9369 says he thinks I can run 30" x 10.5" in an I.R.S. with proper offset trailing-arms/wheel back-spacing.
Besides, I'm not sure how much it'll 'squat' with the 4-link/coil-over suspension.
If 30" x 10.5" will 'clear' everything in an I.R.S. application, unless I'm worng (or, 'wronger-than-usual')the only way it won't work with a solid-axle rear is if I can't get wheels with correct back-spacing to fit with the 10-bolt Z28 rear end, centering the tires in the available 'space'.....
