BW-t10..how tough?
Old Jul 24, 2004 | 11:29 AM
munday's Avatar
munday
Default BW-t10..how tough?
how tough are they. I have a aluminum flywheel 16lbs, and somewhere a centerforce clutch(not sure if either of these affect the life of a tranny but fyi) how much power can this thing take as a weekend warrior?
oh yeah and this guy is great -->
Old Jul 24, 2004 | 11:49 PM
Solid LT1's Avatar
Solid LT1
The T10 is rated for 375 ft/lbs of torque by Richmond Gear. I wouldn't have a problem with one behind a 383 stroker as long as you never put a set of slicks on it. The Muncie is a stronger transmission (especially the M22 gear set, if you can live with the noise.) 1974 and later Vettes had T10 transmissions, some people like to call them "Super T10" but, they do not have the cast iron main case and high nickle gears of a true Super T10 and even these are somewhat fragile as the gears are narrower than a Muncie 4 speeds gears. The 2.64 or 2.88 1st gear T10s are great street transmissions, I ran one for several years in my 302 Z/28 (no torque in that motor!) The T10 is a little longer than a Muncie 4 speed (about 3/4" longer) so you will need a 1974 or later driveshaft for the swap (or pay to have the driveshaft cut to a proper length.) The THM400 transmission yoke will slide right in as will any 1971 or later Muncie yoke.
Old Jul 26, 2004 | 11:50 AM
munday's Avatar
munday
i plan on running nitto extreme drags and sprayins some nitrous. hmmmm
Old Jul 26, 2004 | 12:01 PM
dfseidel's Avatar
dfseidel
Wait, I thought the '74 was the last year that the Muncie was used in the corvette with '75 starting the Super T10....
Old Jul 26, 2004 | 12:13 PM
thevetterisbetter's Avatar
thevetterisbetter
I have an original M21 in my 74.
To BW-t10..how tough?
