Coilovers vs. leaf and bilsteins.
Old Jul 27, 2004 | 03:27 PM
munday's Avatar
munday
Default Coilovers vs. leaf and bilsteins.
what is everyones take on this? I am searching for the sharkbites the Cali has but no luck yet. Are they worth the added expense? I won't be professional autx, but i will be hitting the track as much as possible.
Old Jul 27, 2004 | 03:43 PM
norvalwilhelm's Avatar
norvalwilhelm
Check out his latest post
http://forums.corvetteforum.com/showthread.php?t=870028
Old Jul 27, 2004 | 03:51 PM
munday's Avatar
munday
so i'm guess it's a big no on the coilovers....good...
Old Jul 27, 2004 | 07:45 PM
Mike Smith's Avatar
Mike Smith
I've got them on my '66 and I like them. I wish I had more downward adjustability, however. Another inch or so would be plenty.
Cali also wanted more downward adjustability and on the advice of Speed Direct, began cutting coils off the springs. He apparently cut more than the design would permit (again - he was advised to do so by SD) and the springs became loose, producing the noises he described in his posts.
One feature I wanted in replacing my conventional springs and shocks was adjustability. This limited my choices to the coilovers from SD, the coilovers from Van Steel, and the monospring from Vette Brakes. I don't know if the other two choices would have lowered my car any more than the SD coilovers. For all I know, I may, in fact, have the best system of the three as far as downward adjustability goes.
I do like the firm tight feeling of the coilover front suspension compared to stock setup, just wish it was a little lower from an appearance standpoint.
Old Jul 27, 2004 | 11:19 PM
Schmucker's Avatar
Schmucker
If you're not going to take the time to put full coilovers on then it's just not worth it. If you want a good bolt in setup then I would just do the monoleafs.
Old Jul 27, 2004 | 11:20 PM
munday's Avatar
munday
thanks for the advice, i'll be sticking with the leafs and the bilsteins.
Old Jul 28, 2004 | 11:36 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
If you want your front end bouncing around like a basket ball than sure go that route. Unless you plan on modifing your frame, you can not run true coilovers. I have QA1 semi-coilovers and have never had a problem nor has anyone who bought them from me.
Old Jul 28, 2004 | 11:47 AM
Schmucker's Avatar
Schmucker
And I did modify my frame and I did put QA1 Full coilovers in, just as my signerature says that I did. It was time consuming and not as easy as just bolting something in, and due to the poor design of the semi-coilover setups I suggest not going with them. A road racer car is going to be lowered a good put to keep the air out from underneath and the semi-coilover setup doesn't allow for that. Putting together your own semi coilover with a different shock with the proper travel and you may have something.
Old Jul 28, 2004 | 11:49 AM
Twin_Turbo's Avatar
Twin_Turbo
Where's the pics of the front schmucker? I think I saw your rear setup (with the blue diff. crossmember/coil over mount right?)
Gotta say, I agree with you. Either go full coil overs or don't do it at all. Half azzed stuff doesn't appeal to me at all.
Old Jul 28, 2004 | 12:04 PM
Schmucker's Avatar
Schmucker
The link to the front was in the post about the rear. I had posted about the front a while ago because I finished it first. That tread is no longer available though. If I get my brakes working today it won't be too long and I'll have some driving impressions to post about.
Old Jul 28, 2004 | 01:43 PM
Van Steel's Avatar
Van Steel
Sorry I don't read everyones signature and most guys do not have the equipment or the know-how to modify their frame. As you know, it probably was not a one shot deal either. How low is your ride height up front? I got mine down to 26.5" from the ground to the center of the wheel well lip but I also have stock rims and tires. Got any pics?
Old Jul 28, 2004 | 03:46 PM
Twin_Turbo's Avatar
Twin_Turbo
schmucker, you don't have the pics online so I can look at them?
Old Jul 28, 2004 | 05:35 PM
norvalwilhelm
I agree with Twin turbo. I never liked the lower mount on the semi coil overs and would never go that route or the mono leaf. I feel it is just as bad.
I did go full coilovers but it is alot of work, requiring alot of cutting and welding. I feel the stock setup is good, better then the 2 options. This is a shot of my setup, but agian it is beyond most peoples ability.
Old Jul 28, 2004 | 07:59 PM
Schmucker's Avatar
Schmucker
Right now it's 25.5 and it hasn't fully settled (haven't been able to drive the car yet). It looks just awesome like that, but I'll have to see how it likes the roads. This is with 245/60R15s on stock Rally wheels.
And I have to pimp my own suspension since Norval pimped his
http://csagent.homestead.com/files/c...ersdone005.jpg
Too bad I don't have a good picture or a camera that doesn't suck. It's not resized so I'm not putting the image tags in. There are plenty more crappy pics available.
Old Jul 28, 2004 | 09:05 PM
norvalwilhelm
Yours is the same as mine but I can drop the shock and spring out the bottom for quick spring changes. 10 minutes from start to finish per wheel changing a spring.
The principle is the same just different size holes in the lower A arm.
Old Jul 28, 2004 | 11:01 PM
Schmucker's Avatar
Schmucker
I left mine like that so I can run a normal spring if I had to.
Old Jul 29, 2004 | 12:58 AM
Cali,68,L-79's Avatar
Cali,68,L-79
As I have 4 months of messing with these S.B. coil-overs I would suggest to you Mike that you NEVER EVER cut the springs. i had to becuase I'm running 245/60/15 tires but if I had stock 70's than the setup would work. With that said I have drivien my 68 for 2 weks straight as my Honda is in the shop and I can tell you the stock system is as bit as good as the S.B. and $950.00 cheaper. I now am able to get the sytem tore apart, springs cut and reinstalled in under 30 minutes per side. I guess doing ten times makes you an expert , unfortunetly.
To Coilovers vs. leaf and bilsteins.
Old Jul 29, 2004 | 08:31 PM
Mike Smith's Avatar
Mike Smith
As you know, I've been following your trials and tribulations with great interest. I have no intention of cutting these springs.
I am disappointed SD did not offer you a solution such as shorter springs, modified shocks, under-the-arm mount, or a combination thereof.
Anyway, I'm glad you've got your car where you want it. As I mentioned once before, its the only Vette I've seen that would tempt to own another black car.
Beautiful ride!
Old Jul 29, 2004 | 09:48 PM
LiveandLetDrive's Avatar
LiveandLetDrive
So the composite springs cause bounciness... but if you're getting fully adjustable (I'm thinking QA1) shocks anyway, can't that be tuned out?
-Chris
Old Jul 29, 2004 | 11:53 PM
Cali,68,L-79
-Chris
