LF brake caliper won't release!
Old Jul 28, 2004 | 10:01 AM
76greg's Avatar
76greg
Default LF brake caliper won't release!
Hi,
My left front brake caliper won't release and keeps the wheel locked.
I have rebuilt all the calipers and this one is giving me problems. If I crack the bleeder valve to release brake fluid pressure it frees up until I apply the brakes again then the same thing happens. This is not brake pad drag, this is locked, I can not move the wheel. Any Ideas other than new calipers?????
Thanks! Greg (76 coupe)
Old Jul 28, 2004 | 10:07 AM
VBP's Avatar
VBP
St. Jude Donor '07,'13
Try changing the front left brake hose. The inner part of the hose deteriorates and comes apart sometimes.
Tony
VBP
Old Jul 28, 2004 | 11:17 AM
76greg's Avatar
76greg
Tony,
Would that cause the fluid to not move backwards after the pedal is released? Like a one way valve???? I have new hoses but have not installed them yet.
Thanks! Greg
Old Jul 28, 2004 | 11:21 AM
VBP's Avatar
VBP
76greg,
Yes, there may be some debris inside the hose blocking it.
Tony
VBP
Old Jul 28, 2004 | 11:59 AM
76greg's Avatar
76greg
Thanks Tony!
I will swap all the brake lines with the new ones!
Greg
Old Jul 28, 2004 | 12:05 PM
comp's Avatar
comp
Originally Posted by 76greg
Thanks Tony!
Greg
when one goes the others probably need it also
To LF brake caliper won't release!
