Accel HEI recurve kit
I installed it how I thought and with 36 degrees total advance I am at 24 initial at 600 rpm... ouch (yes the vacuum advance is disconnected) I pushed the weights all the way out with no springs to make sure the rotor wasn't interfering... all good. Drilled the bushing out a little so the weights swing easily in and out. Light lube on things... The action is very smooth. I pulled the distributor and cleaned everything up and relubed where necessary.
so, anyone using this setup?
off to get a new starter, this one is just about done.
