Long water pump
Jul 29, 2004 | 03:24 PM
Cruise-In IV Veteran
Cruise-In V Veteran
Long water pump
Is there any reason a long water pump cant be used on our cars?
Jul 29, 2004 | 03:47 PM
The vette pump is 'special', it is heavy duty with a 3/4" snout (thing the pulley slides onto) while most pumps are 5/8" and they are also a touch longer than a short pump from what I understand. The pumps where also used on trucks.
I think you can use a long pump with a sb if you change out the pulleys and brackets, think a bb long pump will make the crank pulley hit the crossmember.
Jul 29, 2004 | 03:51 PM
Cruise-In V Veteran
I want to use the long pump because I can change out the brackets.
Jul 29, 2004 | 04:21 PM
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Switch to elec fans and you won't have a problem.
Jul 29, 2004 | 04:44 PM
Short pump and long pump diffenece other than shaft is the pulley alignment....with crank, power steering, a/c, alt...lot of hassle to make sure you dont flip belts.
Jul 29, 2004 | 04:50 PM
Cruise-In V Veteran
I plan on new pullies and brackets.
Jul 29, 2004 | 04:54 PM
not the issue...you may have an issue with the "squareness" from upper
pulleys lining up with crank pulleys...may need to add spacer to crank...
Jul 29, 2004 | 05:03 PM
Cruise-In V Veteran
Ahhh OK that makes sense. thanx
Jul 29, 2004 | 05:21 PM
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
Quote:
This is true, I am also switching to serpentin setup from a 91
rs camaro. only one belt.
but you have to use good electric fan/fans
Jul 29, 2004 | 05:22 PM
Quote:
Be sure and post pics when you are done with this conversion.
Jul 29, 2004 | 07:22 PM
Cruise-In V Veteran
Its gonna be awhile I am heading to korea for awhile. I am gonna build a new engine from scratch.
