Pitman Arm Removal Help
Old Jul 30, 2004 | 11:09 PM
VETDRMS's Avatar
VETDRMS
Default Pitman Arm Removal Help
I am in the process of pulling the power steering to install the manual center link and pitman arm and I'm having a heck of a time getting the pitman arm off the steering box.
I used a two jawed puller and it was taking a LOT of force and one of the jaws broke.
Obviously its on there pretty tight.
Any Ideas?
Thanks!
Old Jul 31, 2004 | 01:11 AM
Disco_Mike's Avatar
Disco_Mike
ttt for you.
Old Jul 31, 2004 | 08:04 AM
comp's Avatar
comp
did you tap on it with a ham. with the puller applying pressure ?
Old Jul 31, 2004 | 08:27 AM
Richard Cooper's Avatar
Richard Cooper
get a pitman arm puller, its also a two jaw puller, but much stronger than a regular puller. Its designed just for the pitman arm. I had the same trouble as you are having, bought the puller and pitman are came off. It takes a lot of pressure to remove arm. I got my puller at Auto Zone, it cost $16.99.
Old Jul 31, 2004 | 08:30 AM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
You might want to try a pitman arm puller. Usually you can rent one at certain auto parts stores. I believe Pep Boys has them available. You might need to get a little heat on it if it still won't budge, but that may cause the need for a new shaft seal as well.
Old Jul 31, 2004 | 09:30 AM
75 Hot One's Avatar
75 Hot One
I posted a similar question a few months ago and didn't get a "magic" answer. I broke a pitman arm puller in the past and finally used a torch to get the pitman arm off. This time I used a two-arm puller which is hard to get in there- make sure you get the right size. The big trick is that you don't rely totally on the puller- if you do, you'll probably break it. You tighten up on the puller, then hit the end of the puller bolt with a hammer a few times. Possibly whack the side of the pitman arm with a hammer as well. The repeated shocks will break the pitman arm loose.
Old Jul 31, 2004 | 09:53 AM
GTR1999's Avatar
GTR1999
I use an impact gun with the pitman arm puller and has worked good so far.
Old Jul 31, 2004 | 10:42 AM
Kid Vette's Avatar
Kid Vette
I just did mine. The pitman arm puller by itself woudn't get it to budge. I put a little heat on it with a propane torch and it popped right off.
Old Jul 31, 2004 | 11:02 AM
PRESSURERAT's Avatar
PRESSURERAT
I dont want to hijack the thread but how tight are you supposed to put it back on? Just impact it or torque or what? I am in the middle of the same project.
Old Jul 31, 2004 | 11:20 AM
75 Hot One's Avatar
75 Hot One
The spec is 185 ft-lbs.
Old Jul 31, 2004 | 12:54 PM
VETDRMS's Avatar
VETDRMS
Thanks for all the info! I was putting tention on it with the puller and hitting it with a hammer, no dice. The last time the puller's jaw just snapped in two...
There is an abundance of power steering fluid in the vacinity so I'm not sure sure I want to use an open flame!
I will go get a pitman arm puller today and give it another shot. I let it soak over night with some WD-40.
As far as torque spec, the Haynes manual says 140ft-lbs.
Where did you get the 185?
Thanks!
Old Jul 31, 2004 | 01:00 PM
Cali,68,L-79's Avatar
Cali,68,L-79
No pressure needed whatsoever. I sat for 2 days with a BFH and found out it fits one way and one way only! The alignment grooves, 2 of them, go on 1 way. I actually pushed it on with my pinky finger, and here I was using a 15 pound sledge hammer before.
Old Jul 31, 2004 | 09:24 PM
68/70Vette's Avatar
68/70Vette
The 1968 Corvette Assembly Manual specifies 120 to 160 ft-lbs of torque. The drawing number is UPC 9 A2. It's page 214 of my manual.
Any tips as to how to hold/brace the pitman arm to put that amount of torque on it? I'm assuming its not a good idea to run the steering box to its stopping position at applying the torque against the gears inside the box.
To Pitman Arm Removal Help
