Pro15 as frame paint/undercoat
Old Jul 31, 2004 | 01:38 AM
Smokin Joe's Avatar
Smokin Joe
Default Pro15 as frame paint/undercoat
Anyone have experience with this stuff as an under coat for the frame and frame components?
How does it do on the underside of fiberglass, like in the wheel wells?
How does it look?
Thanks!
Old Jul 31, 2004 | 01:41 AM
killervette666's Avatar
killervette666
I've used it on a large portion of my frame, and even my trailing arms, and it looks awesome, and doesnt come off, im not sure about fiberglass, but i bet it would stick to it. Overall a great product, im very pleased
Old Jul 31, 2004 | 01:55 AM
Smokin Joe's Avatar
Smokin Joe
bump
Old Jul 31, 2004 | 01:57 AM
VetteNut72's Avatar
VetteNut72
I did my entire frame and all painted pieces with POR-15. Red stuff was painted with POR-15, topcoated with tie coat primer, sprayed red and clearcoated. I love the stuff and would recommend it to anyone
Craig
Old Jul 31, 2004 | 02:19 AM
Smokin Joe's Avatar
Smokin Joe
Great pics!!
Thanks.
How is the durability for a weekend driver?
Old Jul 31, 2004 | 02:24 AM
VetteNut72's Avatar
VetteNut72
Originally Posted by SpyRacing
Great pics!!
Thanks.
You can hit POR-15 coated metal with a hammer, it will dent but the POR will not chip off. The clearcoat I used is called Pelucid and is as hard as POR-15.
Craig
Old Jul 31, 2004 | 08:50 AM
Red_Shift's Avatar
Red_Shift
I'm going to go with Line-X for my underbody. If you haven't heard of Line-X there are other brands out there but I don't know the names. This material is often sprayed in the beds of trucks to make a durable, waterproof, and cosmeticly appealing barrior. The Line-X company said the only time they've ever seen it come off of something was when a 100 lb brick of concrete fell into the truck and the corner hit first. He said even then only about a pencil eraser size piece came off.
The cost for my 1975 is $400 so it's a little pricey. I can't paint to save my life so it's really not much more then I'd be paying the shop to paint the underside anyway and this will provide a lifetime of sound deadining and heat barrior. I'm only going to do this if it doesn't add much weight (5-10 lbs). Any more then that and I'll go with paint.
Just something to look into.
Old Jul 31, 2004 | 10:04 AM
Edzred72's Avatar
Edzred72
who makes it? Is that the full name?
Can you email me some pics. I saw someone use it and it ran, How did you apply it to look smooth?
denis.j.gulakowski@us.army.mil
POR-15 is made by POR-15. That's the product...that's the company. (por15.com) If it ran...then it was applied WAY too thick cause it's self leveling. Since it can be sprayed or brushed, I've used it on numerous engine & frame parts with AWSOME results. Regular POR can withstand up to 300 degrees, so it's great for engine brackets, valve covers, etc. They also sell a high temp paint that can be brushed or sprayed that I've used. Didn't like the coverage of the high temp. Would go with Eastwood "one shot" with hardener for a brush on engine paint. Did my 72 in it and turned out great. Numerous engine parts painted with por pics here...http://www.1-4u-computer-graphics.co...num=1091190073
Eddie
Old Jul 31, 2004 | 10:18 AM
carl a's Avatar
carl a
i used it on my entire undercarrage, frame and sterring, and rear end.2 coats of por-15 and top coat on frame,,,,,,,, 2 coats of por-15 and top coat of metal mask ,,then glisten p.c...have photos on web site---http://www.geocities.com/carlclub2/
To Pro15 as frame paint/undercoat
